Ana içeriğe geç
Nintendo Wii DVD Drive Lens Replacement
Neye ihtiyacın var
  1. Nintendo Wii DVD Drive Lens Replacement, Faceplate: adım 1, 2 resimden 1. Nintendo Wii DVD Drive Lens Replacement, Faceplate: adım 1, 2 resimden 2.
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
    Die Abdeckungen sind geklebt, stecken also nicht.
    Ludger - Yanıt
    Don’t mistakenly remove the rubber case feet
    Bob Trout - Yanıt
    I just did. That picture could be better.
    B G -
    Thanks I almost removed the rubber feet
    Lushane - Yanıt
    If you’re wondering what to use for this, the main blade of a pocket knife from the corner of the plastic works well.
    Cameron Holman - Yanıt
    As you remove the hardware in each step, place them together on a sheet of paper and circle them with the step number.
    Tom J - Yanıt
  2. Nintendo Wii DVD Drive Lens Replacement: adım 2, 1 resimden 1.
    • Remove the two 8.3 mm Tri-Point screws hidden under the covers you just removed.
    Before you start, get a small plastic tray with at least 15 small bins in it, and put the screws you take out in each step in the bins in order. It makes reassembly a LOT easier.
    larry - Yanıt
    NOTE: You need a Y1 screwdriver. Be careful when buying the little red screwdrivers on Amazon that claim to fit the Wii - they don’t!! From personal experience.
    Robotai - Yanıt
    Just to add to Robotai’s comment, if you do get the little red/orange screwdrivers on Amazon, file off the tip. It if’s mostly blunt, it fits the tri-wing screws much better.
    jeff - Yanıt
    1/16 x 1 craftsman Phillips mini screwdriver works for this if you don’t have the tri-wing driver
    grace nicosin - Yanıt
    How do you make one ? If you don’t have the screwdriver
    Ethan - Yanıt
    I am using a 18ct empty egg carton to hold the screws/parts removed in the steps.
    karenmparamore - Yanıt
    Larry’s idea about the bins was great and helpful.
    Robots is right- you NEED a Y1. Just buy the thing with the drive. I didn’t, tried many other options, none worked. Had to order the thing separately with shipping. Mistake….
    David Ryan - Yanıt
  3. Nintendo Wii DVD Drive Lens Replacement: adım 3, 1 resimden 1.
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
  4. Nintendo Wii DVD Drive Lens Replacement: adım 4, 1 resimden 1.
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
    All of the rubber feet on my very old Wii had literally melted into a gooey mess and just needed to be scraper off and cleaned with alcohol.
    Bob Robins - Yanıt
  5. Nintendo Wii DVD Drive Lens Replacement: adım 5, 1 resimden 1.
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
    please help! my lil sis got a disc stuck in my wii while it was off!!! please help fast!!!
    Leah Vegan - Yanıt
    does it turn on?
    Giovanni Munoz - Yanıt
    It won’t come out, it will turn and go up but it won’t go fully out
    Mmbb - Yanıt
  6. Nintendo Wii DVD Drive Lens Replacement: adım 6, 2 resimden 1. Nintendo Wii DVD Drive Lens Replacement: adım 6, 2 resimden 2.
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
    surprisingly, this was the trickiest step for me. I almost completely mangled the wires when my tweezers slipped as I was attempting to remove the connector.
    rbelknap - Yanıt
    I removed it with a spudger, gently lift from each side until it pops out.
    For those reassembling
    line up the pins push it in with your spudger gently until it's in. Then line up the front plate, push gently, confirm everything is where it should be and push firmly, I found it needed a strong push to sit flush with the other body panels.
    James middleton -
    I ended up using needle nose pliars on this step.
    Awesome detailed guide made this very easy, thank you author!
    Glenn Woodard - Yanıt
    Can someone direct me to what I need to do? My tweezers slipped and I cut one of the wires on the connector. Where can I find a new Y plug for the wii?
    jaredslaweski - Yanıt
    I also broke my wire trying to use tweezers. I should have known better. I use (normally do) a spudger on one side and my fingernail on the other to gently pry these types of connectors out. I ended up buying a replacement faceplate on ebay.
    Tyler - Yanıt
    This was the hardest part for me. I tried using my fingernails, two different tweezers, and needle nose pliers, but I ended up cutting both the wires. Anyway, I put some electric tape over the exposed wires and just reassembled the system. Funny thing is that the LED still works and I have not noticed any difference. I'm not sure what those wires did, but they seem to not be important.
    Nick - Yanıt
    For people still wondering after all these years, :), The connector is for the blue leds around the dvd when loading and unloading a disk.
    Niels -
    I also broke off the flimsy wires at the connector. To NOT break the wires, alternate pressing on the right and left sides of the connector with a small flathead screwdriver. Be patient, it will eventually work itself free. There isn't enough to grab onto with the tweezers and you'll only succeed in having them slip off, grab the wires, and yank the wires out.
    Good news is that if you do rip out the wires, no worries... I didn't reconnect them and the unit works just fine. I have no idea what those wires are even for. Power LED continues to work no problem.
    jasendorf - Yanıt
    I used two small flat head screw drivers, one on each side to pry out the connector. This created less pressure from me and reduced my chance of cutting the wires.
    mulkey - Yanıt
    This guide is really marvellous - works a treat. But I would definitely recommend needle nose pliers for this step rather than tweezers. It's really easy if you use pliers and potentially damaging if not, and you get it wrong. I had one sniff at it with tweezers then immediate nipped out to the garage for my pliers!
    thepitcanary - Yanıt
    Definitely a tricky step with that connector. I also cut broke the wire accidentally and was going to just give up trying to fix the Wii. However, as others stated the Wii works just fine, including the lights. I do wonder what those wire are for.
    darcaesar - Yanıt
    I also had a lot of trouble trying to get the connector off with tweezers. Ended up leaving it attached. It does not really get in the way of remaining steps.
    Ron Even - Yanıt
    Needlenose pliers did the trick for us!
    Ron Cormier - Yanıt
    Needlenose pliers did it for us!
    Ron Cormier - Yanıt
    You can save yourself some trouble at this point and skip the rest of the disassembly: See that green tab to the left of the sd card slot? THAT’S the wifi board (and that green tab, in hindsight, seems designed to make it accessible without taking apart the whole device, don’t you think?) A little careful spudging, and you’ve got it out, ready to replace! (There’s a guy who shows the process on youtube, if you want to review first)
    Will - Yanıt
    I got the connector out ok thanks to the suggestions here, but I couldn’t figure out how to reattach it. In the end, I just kind of threw it in and it worked fine.
    Christine Wittmer - Yanıt
    Very clear instructions - thanks! Faceplate needed replacing after one of my son’s friends accidentally kicked it across the room. $10 bucks to fix, thanks to ebay and these instructions. I’d never heard of a “tri-wing” screw before.
    LInda Rawlins - Yanıt
    I just left the connector alone and kept it connected while working on it. There is enough wire to allow you to do what you need if you are just careful not to snag it on anything.
    Michael Payne - Yanıt
    I, too, left the connector attached and just took care that the loose faceplate did not stretch the (not crucial) wire when moving rest of the Wii.
    Matti Haveri -
    This was the trickiest part, I almost broke the wires using tweezers and pliers, so instead use a flat end screwdriver to pry it out, when putting it back in use needlenose pliers to start it then use your fingernail to go the rest of the way.
    After I got the connector out I noticed the little locking flap on the top side of the connector. I think prying this first is the key to easier removal.
    Will B - Yanıt
    Anyone know of a method to replace the connector if you end up breaking the wires? Bits of wire are stuck in the white plastic connector, so I'm wondering if I can buy a connector online somewhere without replacing the whole face plate. Thanks :)
    Bronze Owl - Yanıt
    I severed both wires. If you want to avoid removing the connector, you can lengthen the two wires by unserpentining them from the wire holder that's in the cover.
    Griff Derryberry - Yanıt
    Make sure there is no SD card in your unit before pulling this off, otherwise it'll get stuck and you could snap your sd card in half!
    carlosahiciano - Yanıt
  7. Nintendo Wii DVD Drive Lens Replacement, Outer Case: adım 7, 3 resimden 1. Nintendo Wii DVD Drive Lens Replacement, Outer Case: adım 7, 3 resimden 2. Nintendo Wii DVD Drive Lens Replacement, Outer Case: adım 7, 3 resimden 3.
    • Open the controller port cover until it is perpendicular to the black controller port bezel.
    • Pull the controller port cover straight up to release it from the outer case.
    • Repeat this procedure for the memory card port cover.
    I wasn't able to reassemble the socket covers when I reversed this step..
    While disassembling, I did as instructed pulling the covers upwards when they where perpendicular to the black cover plate but Nintendos instructions says to open the covers (so that they are perpendicular to the black cover plate) and then gently push the covers towards the console with your fingers on the outside of the cover opposite side of the hinges so that the cover hinges will pop out and then lift it up..
    I'm not sure, but I think ignoring Nintendos instructions caused the hinge sockets to break for me, so replacing the controller/memory card socket covers will not work.
    When reassembling, the cover can be placed perpendicular to the black cover plate and rest on the plastic hinge with a few millimeters between the cover and the console, and then they can be pushed down to click in place. But in my case they keep falling all the way down since there's no resistance and nothing to click into.
    Martin Johansson - Yanıt
  8. Nintendo Wii DVD Drive Lens Replacement: adım 8, 2 resimden 1. Nintendo Wii DVD Drive Lens Replacement: adım 8, 2 resimden 2.
    • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
    • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
    The 3rd hole is in step 3.
    James middleton - Yanıt
    The bezel is the flat black plate. Removing the three screws that secure it allows you to remove it. If your cube is like mine, this plate likes where it lives and, even with the screws removed, managed to stay in situ without anything holding it.
    Dennis Johnston - Yanıt
    Beware. The edge of the bezel, opposite these screws, has clips. Lift the bezel from the top edge, where the the screws are, to avoid breaking these clips.
  9. Nintendo Wii DVD Drive Lens Replacement: adım 9, 1 resimden 1.
    • Remove the two 5 mm Phillips screws above the controller ports.
  10. Nintendo Wii DVD Drive Lens Replacement: adım 10, 1 resimden 1.
    • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
  11. Nintendo Wii DVD Drive Lens Replacement: adım 11, 1 resimden 1.
    • Remove the following screws:
    • Two 5 mm Phillips screws
    • One 8.2 mm Tri-Point screw
    Instead of the Phillips screw on the left I had a very small one under a cover to the left of that!
    Donna Vought - Yanıt
  12. Nintendo Wii DVD Drive Lens Replacement: adım 12, 1 resimden 1.
    • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
  13. Nintendo Wii DVD Drive Lens Replacement: adım 13, 1 resimden 1.
    • Remove the two 8.2 mm Tri-Point screws hidden under the feet you just removed.
    • You may use a 4 mm hex driver to extend your bit into the recesses and reach the screws.
    had a little trouble with theses screws. they were just barely too deep for my 54pies bit driver kit to reach. I ended up inserting a small wad of paper into the shaft of my driver so the tri-wing bit stuck out far enough to engage the screw. (I used the tweezers to remove the paper when I was done) :)
    rbelknap - Yanıt
    I can confirm, this works fantasticly!
    Thank you
    James middleton -
    When putting the screws back in hold the tip still with the screw and carefully drop it in.
    James middleton -
    Thank you rbelknap, this is excellent advice for those using the ifixit branded driver.
    George Squires - Yanıt
    You could also use the 4mm nut driver in the iFixit kit to turn the tri-wing driver. This will give you a little more reach.
    Edward Tucker - Yanıt
    How is no one talking about the included 4mm nut driver trick at Edward Tucker mentioned?! That is genius! Thanks mate!
    Zabuza -
    That's the idea that I needed. Agree with Zabuza.
    cwdick -
    Bingo. All of the other comments were unnecessary.
    Tony Shannon -
    Because it doesn't come with the screw driver in the kit. Only has the tri wing and the cross tips.
    Craig Goodsell -
    This paper wad trick totally worked for me too!
    anonymous 779 - Yanıt
    Standard Tri-Wing bits will NOT fit into the holes. Make sure that you get one of the tool kits from iFixit (I just ordered the Mako Driver/Bit kit with 64 bits ) - the Tri-Wing bits in this kit have a narrow shaft that allows it to reach deep into narrow holes like these on the Wii . (Disclaimer - I have no association with iFixit).
    dave whale - Yanıt
    I just sawed off a bit of the shank holder from the iFixit tool, in order for the bit to go deep enough into the case.
    The tool still works fine.
    Alan Walker - Yanıt
    Thanks for the paper wad trick advice! Worked perfectly with my Wii
    Finder352 - Yanıt
    The 4mm driver was the exact fix for this problem, no mods necessary
    Tony Shannon - Yanıt
  14. Nintendo Wii DVD Drive Lens Replacement: adım 14, 1 resimden 1.
    • Lift the outer case straight up off the body of the Wii.
    This step could use at least another picture from the backside so it's clearer what comes up and what stays down.
    Jose Vazquez - Yanıt
    I used a spudger around the edges of the outer case to gently ease it upward since I could not lift it out with my fingers. Then it came right out.
    Marko - Yanıt
    Good tip. Having, in the past, broken pieces that required a little persuasion, I attempted to "lift" the outer case, but it wouldn't budge. Using the spudger to persuade it worked like a charm. Also added this suggestion to Step 18 "Lift the drive shield."
    Dennis Johnston -
    hey marko that really helped me thanks\. als if you need help figuring which side is up, its the one with the nintendo engraving on it
    Aryan Garg - Yanıt
    A fan filter fell out at this step how do you put it back?
    Edit: I figured it out it was from the side intake vent. Just line up the two notches with the pegs in the case to hold it in place
    Darren Jones - Yanıt
    This is an awful guide
    Alexander D Schaefer - Yanıt
  15. Nintendo Wii DVD Drive Lens Replacement, DVD Drive: adım 15, 2 resimden 1. Nintendo Wii DVD Drive Lens Replacement, DVD Drive: adım 15, 2 resimden 2.
    • Remove the small Phillips screw securing the battery door to the bottom panel.
    • This screw is captive to the battery door.
    • Pull the battery door out of the Wii.
    • The system time will be reset once you remove the battery door.
    • This is a good time to change the CR2032 battery if it hasn't been changed recently.
    The screw on the battery door of my Wii required a Phillips #000 screwdriver, which is not listed in the required tools.
    Ben - Yanıt
    The screw is a PH0000 (quadruple zero) requiring an exceptionally small Phillips screwdriver to remove. If this is your first time in here in a while, this may also be a great time to change the CR2032 battery.
    Steve Bonds - Yanıt
    I was able to use the ph0 no problem.
    Darren Jones -
    I used a 00 with no problem.
    julie -
    What does this battery do? I never knew there was a battery inside of the WIi.
    Stephen Thornhill - Yanıt
    thje battery is used to maintain timwe and date etc
    Electronik -
    Where can we get a new battery from?
    Chriul Rg - Yanıt
    You can get a CR2032 batterie in your local supermarkt. It is recommended to change it after 5 years, but I have seen devices run for 15+ years.
    Playa -
    my wii survived 15 years already with the same battery
    Bas Molendijk - Yanıt
  16. Nintendo Wii DVD Drive Lens Replacement: adım 16, 1 resimden 1.
    • Remove the 8.2 mm Tri-Point screw that was hidden beneath the battery door.
    Note - this screw is a machine screw (e.g. not self-tapping). It screws into a hex nut, and that nut is captive in a slot in the case. When reassembling, ensure that this hex nut is still captive, and has not migrated out to other areas within the Wii.
    dyanetti - Yanıt
    The other drive cage hole is screwed in step 11, continue to reassemble.
  17. Nintendo Wii DVD Drive Lens Replacement: adım 17, 1 resimden 1.
    • Remove the two 8.2 mm Tri-Point screws securing the DVD drive shield near the controller ports.
    The screw on the right for my wii just refuses to come out
    Robert Menocal - Yanıt
  18. Nintendo Wii DVD Drive Lens Replacement: adım 18, 1 resimden 1.
    • Lift the DVD drive shield upward and remove it from the Wii.
    Be careful not to cut your fingers on the sharp edges of this metal shield. My daughter actually scraped enough skin to cause blood to drip off her finger. Then we noticed her skin stuck to the metal edge. Yuk.
    J Smith - Yanıt
    True story I did it to myself lol
    James middleton -
    Does the dvd shield need to be there? I want to remove it but im not sure if i should
    Kadamo - Yanıt
    If the drive shield needs a little extra persuasion, us a spudger around its perimeter. Also helps prevent cuts when force meets resistance on this metal shield.
    There are spring steel tabs on both sides.
  19. Nintendo Wii DVD Drive Lens Replacement: adım 19, 1 resimden 1.
    • Remove the four 9 mm #1 Phillips screws securing the DVD drive to the bottom panel.
    The two left hand screws were very difficult to relocate during reassembly. I was coaching my 8 year old through this, and this was probably the only step that he couldn't do. We dropped these screws several times, and used magnets to retrieve. Miniature needle-nose pliers gripping the 'washer' surface of the screw were too wide. We managed to purchase the 'button head' of these screws with the needle-nose and drop the screws into their hole, and push with the phillips until secure. I would like to hear how others install these screws, please.
    dyanetti - Yanıt
    I had the same problem as you and eventually found an easy way round it. I wrote this to be added to the instructions but it was rejected: "Once the DVD drive has been removed, remove the 4 rubber washers from the screws removed earlier and insert them into your new DVD drive. Because two of the screws are difficult to reach, it is best to insert these two screws into the washers and then slide them into place ready for securing to the base plate".
    The rubber washer holds the two screws roughly in position, you can then reach them with your screwdriver through the two holes (about an inch away) and finish tightening them up.
    Gary -
    For the two screws at the front of the chassis, use a three-pronged parts retriever to lift them out after you unscrew them.
    Walter - Yanıt
    Helpful tip: Use a magnetized screwdriver for the 2 screws nearest the DVD face because they are set in deep sockets
    Blake Minghelli - Yanıt
    During reassembly, it can be tricky to position the recessed screws. To temporarily magnetize your screwdriver, rub the tip against a magnet for 5-10 seconds. (A refrigerator magnet will do.) You should then be able to put the screw on the tip and gently lower it into position.
    Matt D - Yanıt
    Thanks - the refrigerator magnet trick worked for me,
    Jim Allen -
    Another method for getting the front screws back in is to insert a small pair of tweezers through the DVD slot to guide the screw in. I just dropped the screw in between the tweezers which held the screw just above the hole. Then I was able to use the phillips screwdriver to guide the screw into the hole and screw it in. Done in just a few seconds.
    Another option would be to stick a dab of hot glue on the screw to your screwdriver and then when the screw has been driven home either the glue stays on the driver and is easily removed or it stays on the screw and you just pull it off with tweezers or needle nose pliers.
    accts4mjs - Yanıt
    The screwdriver provided in the kit by ifixit is a magnetized screwdriver and works perfectly!
    mulkey - Yanıt
    If you are disassembling your Wii because, say, a two-year-old has shovelled pennies into it (yes, that was me) you will also need to partially disassemble the drive itself, which is not covered in this guide. Luckily it's really easy. Unscrew the 4-5 larger Philips/cross head screws on the top of the frame (NOT any of the smaller darker ones) around the edges, and the frame on top of the drive will lift right off. Be careful as there is cabling running to it, so don't yank it or pull it too far off. You will now be able to get any coins or other foreign objects out.
    I didn't have a magnetic screwdriver, so I applied a tiny amount of fabric glue to the head of each screw, waited a minute for it to start to harden, inserted my non-mag screwdriver into the screw head, and the screw stuck to the screwdriver long enough to insert it into the hole.
    Lee Crooks - Yanıt
    Be advised that the posts that these screws go into are very fragile and may even break. Make sure to get the little plastic pieces out if you over tighten them or they are just brittle and broken to begin with. The screws seem to be long enough to work if you do break the posts off completely.
    I needed a size 1 Phillips screwdriver for this step.
    julie - Yanıt
    Thanks, I will include it in the guide
    Angel -
    Be careful with these screws - they seem to be quite malleable and easy to strip.
    Electronik - Yanıt
    I ended up using an extra fine tweezers from a watch kit, stuck it through the vent opening "inside" the screw area and acted as guideposts to thread in. Only because I didn't have a magnet for the screw.
    kwjayhawk - Yanıt
    I guess this is a warning applicable to anything that has to do with plastics, but this step in particular: Be extra careful not to overtighten these screws when reassembling the unit because the plastic sockets will easily break/shatter..
  20. Nintendo Wii DVD Drive Lens Replacement: adım 20, 1 resimden 1.
    • Lift the side of the DVD drive opposite the controller ports enough to access the cables on its bottom face.
    • Carefully pull the DVD drive power cable out from under the plastic shroud near the heat sink.
    When reversing these steps to reassemble the Wii, at this point it is possible to do a quick test before screwing the drive to the case. This will save you a lot of time if something is wrong.
    Don't touch anything you don't have to while the case is off.
    Carefully plug the power cable into the back of the Wii, then use a screwdriver to gently press the white button next to the glowing yellow LED on the front. You should hear the DVD drive power up and whir. Then press the white button again, wait for the yellow light to come back, and unplug the Wii.
    If you didn't hear the drive start up, most likely one of the two ribbons isn't connected to the drive correctly. Doublecheck the previous 3 steps.
    Matt D - Yanıt
  21. Nintendo Wii DVD Drive Lens Replacement: adım 21, 1 resimden 1.
    • Pull the DVD drive power cable away from its socket on the DVD drive.
    When reversing this step, be careful re-inserting the connector. The pins are very delicate and if you aren't at the proper angle, you can bend them and ruin the drive.
    jisakoff42 - Yanıt
    The exact thing happened to me just now; I reinserted it at a (very slight) angle, and bent one of the pins at the end of the socket. Luckily, I was able to straighten it back up with a sewing needle. I made sure the spacing was consistent with the rest of the pins, and that I reinserted the connector as straight as I could, so it doesn’t happen again.
    Jose Olarte III -
  22. Nintendo Wii DVD Drive Lens Replacement: adım 22, 2 resimden 1. Nintendo Wii DVD Drive Lens Replacement: adım 22, 2 resimden 2.
    • Use your fingernail to flip up the retaining flap on the DVD drive ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the DVD drive ribbon cable out of its socket.
    • Remove the DVD drive from the Wii.
    When reversing this step, make sure the ribbon is all the way in. For some reason I found positioning it with my replacement drive was much harder than with my old drive. The gentlest tug after lowering the brown clip would show that the ribbon was not actually being held tightly. I thought for a while that the clip itself was broken, but eventually I got it to hold the ribbon correctly.
    Matt D - Yanıt
    Be careful with this step. I too had difficulty re-inserting the ribbon. I even popped off the brown clip and thought I broke it. Thankfully it snapped back into place.
    Dana Kennard - Yanıt
    It is difficult to tell, but be aware that the brown piece is the retaining flap, not the light piece , which is the actual socket.
    Dan Neunaber - Yanıt
    I had to use Kapton tape. I couldn’t get the clip back on.
    Jim Allen - Yanıt
    This was the trickiest step for me. Take note of how the ribbon is configured before you loosen the clip to help you replace it with confidence in the right way.
    Ping Wu - Yanıt
    Careful! When reinstalling, I think I bent and broke the ribbon. The Wii doesn't respond upon power up - I think because it doesn't see the drive.
    Steve Bennett - Yanıt
  23. Nintendo Wii DVD Drive Lens Replacement, DVD Drive Lens: adım 23, 1 resimden 1.
    • Pull the disc detector ribbon cable straight out of its connector with a pair of tweezers.
    If you’re doing a drive swap this step in not necessary.
    netdude21 - Yanıt
  24. Nintendo Wii DVD Drive Lens Replacement: adım 24, 3 resimden 1. Nintendo Wii DVD Drive Lens Replacement: adım 24, 3 resimden 2. Nintendo Wii DVD Drive Lens Replacement: adım 24, 3 resimden 3.
    • Use the tip of a spudger to push the sides of the ZIF connector fastener securing the spindle motor ribbon cable directly away from the connector.
    • Disconnect the spindle motor ribbon cable by pulling it straight out of its connector with a pair of tweezers.
  25. Nintendo Wii DVD Drive Lens Replacement: adım 25, 2 resimden 1. Nintendo Wii DVD Drive Lens Replacement: adım 25, 2 resimden 2.
    • Remove the piece of black cloth tape that covers a portion of the lens ribbon cable.
  26. Nintendo Wii DVD Drive Lens Replacement: adım 26, 3 resimden 1. Nintendo Wii DVD Drive Lens Replacement: adım 26, 3 resimden 2. Nintendo Wii DVD Drive Lens Replacement: adım 26, 3 resimden 3.
    • Disconnect the lens ribbon cable by first pushing the two locking tabs of the ZIF connector towards the ribbon cable with the tip of a spudger.
    • Use a pair of tweezers to pull the lens ribbon cable straight out of its connector.
    Re-assembly comment: After re-connecting the lens ribbon cable is a great time to remove the solder blob from the replacement lens.
    Tom - Yanıt
  27. Nintendo Wii DVD Drive Lens Replacement: adım 27, 1 resimden 1.
    • Remove the two 5.0 mm Phillips screws securing the DVD drive board to the drive housing.
  28. Nintendo Wii DVD Drive Lens Replacement: adım 28, 3 resimden 1. Nintendo Wii DVD Drive Lens Replacement: adım 28, 3 resimden 2. Nintendo Wii DVD Drive Lens Replacement: adım 28, 3 resimden 3.
    • Lift the DVD drive board off the drive housing by first lifting the side with the lens ribbon cable connector.
    • Pull the opposite side of the DVD drive board straight out while lifting the entire board straight up to free it from the small black plastic tabs holding it in place.
  29. Nintendo Wii DVD Drive Lens Replacement: adım 29, 1 resimden 1.
    • De-route the cables that are soldered to the DVD drive board from underneath their black plastic tabs with the tip of a spudger.
    I found it was easiest to unwind red and brown first and then white, blue, gray, yellow.
    Carol - Yanıt
    I found this was easiest one wire at a time
    Tom - Yanıt
  30. Nintendo Wii DVD Drive Lens Replacement: adım 30, 1 resimden 1.
    • Lay the DVD drive board next to the DVD drive in such a manner that the cables soldered to the DVD drive board are out of the way (as shown in the picture)
    • Remove the single 5.0 mm Phillips screw from the DVD lens EMI shield.
  31. Nintendo Wii DVD Drive Lens Replacement: adım 31, 3 resimden 1. Nintendo Wii DVD Drive Lens Replacement: adım 31, 3 resimden 2. Nintendo Wii DVD Drive Lens Replacement: adım 31, 3 resimden 3.
    • The side of the EMI shield with the slot for the DVD lens ribbon cable has two small metal clips that fasten to black plastic tabs on the DVD drive housing.
    • Use the tip of a spudger to bend the two metal clips up enough so that they are no longer fastened to their respective plastic tabs.
    • The EMI shield is made of a soft, malleable metal. It can be easily be bent out and back into shape, but excessive fatigue may cause the clips to break.
    • Make sure both clips are pushed back down into their original positions at reassembly.
  32. Nintendo Wii DVD Drive Lens Replacement: adım 32, 2 resimden 1. Nintendo Wii DVD Drive Lens Replacement: adım 32, 2 resimden 2.
    • Small tabs on the EMI shield sit in two holes on the outside edge of the DVD drive housing.
    • Insert the tip of a spudger into the hole that is closer to the red and pink wires that connect to the DVD drive board.
    • Rotate the spudger to pry the first tab out of its hole on the DVD drive housing.
    Regarding Step 32 and 33 - I did this a little differently, and didn't need to bend (plastic deformation) the tin. Complete Step 31, but instead of 'bending' the clips, you release them and pop the tin up over the plastic 'barb' to release the EMI shield. Then, then repeat Step 31 (popping the tin clips off of the barb) for the two tabs on the opposite side (screw side) of the EMI shield. The EMI shield can then be withdrawn, e.g. released to the bottom of the picture in steps 32 and 33, without bending the tin as advised in step 32 and 33. The only mildly tricky part was releasing the clip from the barb near the (blue/yellow/grey/white) wires connecting the laser stepping motor - I used a fine flat screwdriver.
    dyanetti - Yanıt
    Agree with dyanetti; the two end tabs in step 32-33 are not intended to be bent. Should release all four of the clips on the sides of the plate first, then it will rotate up and the end pins will just slide out (and in when reversing the process for reassembly).
    If you take the top off the dvd drive, these tabs are easy to unlatch from the other side.
    ChrisV - Yanıt
  33. Nintendo Wii DVD Drive Lens Replacement: adım 33, 2 resimden 1. Nintendo Wii DVD Drive Lens Replacement: adım 33, 2 resimden 2.
    • Repeat the action in the previous step to pry the second tab on the EMI shield out of its hole on the DVD drive housing.
    • It may be necessary to hold the opposite edge of the EMI shield to keep any of the clips or tabs from reseating.
  34. Nintendo Wii DVD Drive Lens Replacement: adım 34, 2 resimden 1. Nintendo Wii DVD Drive Lens Replacement: adım 34, 2 resimden 2.
    • Grasp the EMI shield by the two edges that are free and rotate the entire piece slightly towards the edge that is still held down until the final two remaining clips are free.
    • Lift the EMI shield straight off the DVD drive.
  35. Nintendo Wii DVD Drive Lens Replacement: adım 35, 1 resimden 1.
    • Remove the 5.0 mm Phillips screw that is closer to the yellow, blue, white, and grey wires.
  36. Nintendo Wii DVD Drive Lens Replacement: adım 36, 3 resimden 1. Nintendo Wii DVD Drive Lens Replacement: adım 36, 3 resimden 2. Nintendo Wii DVD Drive Lens Replacement: adım 36, 3 resimden 3.
    • While holding the DVD drive with one hand, grasp the DVD drive lens retaining pin (closest to the screw that was just removed) with a pair of needle nose pliers.
    • Slide the retaining pin out towards the edge of the DVD drive housing.
    • Freeing the pin will require some force, and will then become very easy.
    • Once the pin moves easily, grab it with your fingers and pull it out of the DVD drive housing completely.
    There is a small piece of black plastic next to the last screw which was removed. Lifting this up a millimeter or two will release the retaining pin so that it can be moved out easily.
    FRAC - Yanıt
    What to do when these Clips Break?
    Marco Bienert (RodneyMcKay) -
    It's important not to scratch this rod with the pliers. I would use fingertips or plastic tweezers for this step, or wrap the needlenose pliers with tape first.
    ChrisV - Yanıt
    Careful! It’s so easy to break that black plastic piece. Notice that it’s only connected at one end and hinges very easily causing a stress fracture. Whether you lift it from the side or go in through the end hole, minimize the number of times you hinge it.
    I found that vinyl tape-wrapped bent-nose pliers worked well to grip the rod.
    Brian - Yanıt
  37. Nintendo Wii DVD Drive Lens Replacement: adım 37, 2 resimden 1. Nintendo Wii DVD Drive Lens Replacement: adım 37, 2 resimden 2.
    • Grab the DVD drive lens assembly by the side that the retaining pin was just removed from.
    • Remove the lens assembly from the DVD drive housing.
  38. Nintendo Wii DVD Drive Lens Replacement: adım 38, 2 resimden 1. Nintendo Wii DVD Drive Lens Replacement: adım 38, 2 resimden 2.
    • Remove the 4.2 mm Phillips screw that secures the white plastic bracket to the lens assembly.
    • Lift the bracket off the lens assembly.
    • If you are going to install a new lens, make sure to transfer the white plastic bracket and screw to the new laser lens before installation.
    May need an additional step when replacing with a new laser sled assembly: The new one will have a solder blob across two signals for esd protection; this must be removed after the new laser is installed, otherwise it will be completely unable to read the disk.
    ChrisV - Yanıt
    agree with Chris V you have to de-solder the solder dot on ribbon just make a straight vertical line compare it to the replacement laser this should be step 39 because if you don't do this the laser lens will not be able to read properly
    keytechllc - Yanıt
    Had the same issue. I wasted a couple hours troubleshooting the new laser before figuring out that I needed to de-solder the solder blob shorting the 2 signal lines.
    Christopher Daun - Yanıt
    Any tips on removing the screw from the white plastic bracket that needs to connect to the new part? It is not loosening on the old one at all. New mini-philips on order to see if they will fit better and hold but I don't think this is going to come free. Does anyone know where a new white plastic bracket can be ordered?
    eljuline - Yanıt
    Correctly sized philips was all it took. Came off right away. So all set to put it back together tonight.
    eljuline -
    Does the author cares about comments or not? The guide is missing one fundamental step that has been already pointed out by the comments from 4 years ago!!
    Marco Bo - Yanıt
    I too wasted time with this repair until I saw these comments. Completely reassembled, tested, then repeated the whole process again to check all the connections. When I finally found these comments I attempted to remove the solder but ended up with a flakey - partially working wii. I assume I damaged the ribbon cable in the process.
    Ultimately I spent another $20 and bought a new DVD unit ($5 more than the replacement lens) and has my wii working in 15 minutes. I wish I had seen these notes first - I wouldn’t have wasted my time trying to replace the lens. Please, please, please update this guide and save the community a lot of trouble!
    David Begleiter - Yanıt
    Does anyone know where too by white plastic bracket thing
    Hassan Farooqi - Yanıt
Sonuç
137 farklı kişi bu kılavuzu tamamladı.
David Hodson
150.503 İtibar
127 adet Kılavuz yazıldı
25 Yorum
Many thanks for the excellent guide - my wii is working again!
Niel Viljoen - Yanıt
WOW! I have seen a lot of repair manuals and guides, and this has to be one of the best!
Appreciate the care and craftsmanship it took to put this together.
One suggestion: Please add pics of the screws with specs to compare the sizes.
Terry - Yanıt
very informative...if the laser is dirty or the lens is broken....will the tray from the drive come out and go inside...as normal ....please assist...
Techy - Yanıt
All went well. The main problem I had was tweezers of low quality. Also, during assembly, some screws was to tricky, so I needed to magnetize screwdriver and for that purpose I used - a speaker :)
Great tutorial, in deed. David just saved Christmas for me and my family.
Dragan - Yanıt
This is one of the best set of instructions I have ever used. Easy to follow steps with accurate illustrations. Very well done, I don't know how you could make it any better! A++,
camoore4800 - Yanıt
Me too. After solder blob removed, my Wii was able to read GameCube disks and most of my Wii disks.
debrota - Yanıt
Me too. After solder blob removed, my Wii was able to read my GameCube disks and most of my Wii disks.
debrota - Yanıt
Me too. After solder blob removed, my Wii was able to read my GameCube and most of my Wii disks.
debrota - Yanıt
Very useful and detailed.
John Rosenberger - Yanıt
Dare I try this on my own?
Simon Clark - Yanıt
Hola el lente de mi wii no intenta leer, al introducir un dvd el lente da un golpe y luego tres golpes mas, no suena como si intentara leer el disco, de echo tampoco se oye girar al disco, Quisiera saber si este problema es por el laser dañado o si se daño el motor que hace girar el dvd. Mi correo es david19_4@hotmail.com si pudiera ayudarme le agradeceria, puede responderme en ingles yo puedo traducirlo. Gracias
david19_4 - Yanıt
i tried this ix but as i was doing it i flipped the drive over and a small metal clip fell out and cant find where it has to go back in???
can anyone help please?
thanks in advance
dany - Yanıt
★☆★ Top Marks ★☆★ for a well thought out and fantastically illustrated procedure.
My 7 year old son and I worked as a team and it worked like a dream.
The only thing is, that we didn’t originally desolder the bridge on the new lens cable, so we had to work back through to step 22. However, this only took us 20 minutes extra :)
Many, many thanks to Mark and your 7 contributors. ★☆★ Nice Work ★☆★
Ted George - Yanıt
This is one of the most detail oriented tutorial I’ve ever seen. On Step 11, the screws were also color coded to avoid confusion. Great work!
I was able to follow this tutorial and replace the lens module with ease. The Wii system is now able to read the DVDs. Now, however, I have an issue. The Wii console is making a huge din after the replacement. Does anyone this issue? What do I need to do to fix the issue?
Thanks again for a great tutorial!
affansayed - Yanıt
How can I tell if my lens is broken and if it’s in a bad (reversible) condition?
Hunson Abadeer - Yanıt
My two year old stuck playing cards into the disc slot causing no disc to be read. I purchased the Apollo Precision Tool Kit for Phone and Computer Repair, it contained everything I needed to get the job done. I only had to complete through step 19 to push the cards out. Took about 2 hours to complete the project.
Noone Particular - Yanıt
This was a really good guide, I got my Wii working again and I am happy.
Sara Zielinski - Yanıt
Thank you so much!
John - Yanıt
Best disassembly instructions ever!!!
terry.huberts - Yanıt
Thanks for the great instructions, we had no problems getting our Wii working again!
Peter Krystad - Yanıt
nach einbau des neuen laser geht es immer nocht,immer noch die selbe fehlermeldung disk kann nicht gelesen werden
Marco Ott - Yanıt
This is an excellent guide. Thanks for putting it together!
Scott Carter - Yanıt
This was great, thanks! But I did have to look up elsewhere how to desolder the static point on the new laser assembly which I learned about in several videos I watched to get an idea of what I was getting into before I started.
Holly S - Yanıt
this is a lifesaver for my wii!
Cameron Smith - Yanıt
will try this when I get the materials that I need. But so far, this looks pretty promising.
Andrew Burley - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 31
Son 7 gün: 246
Son 30 gün: 1,080
Her zaman: 185,819
