Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Nintendo Wii Faceplate Replacement
Neye ihtiyacın var
  1. Nintendo Wii Faceplate Replacement, Faceplate: adım 1, 2 resimden 1. Nintendo Wii Faceplate Replacement, Faceplate: adım 1, 2 resimden 2.
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
  2. Nintendo Wii Faceplate Replacement: adım 2, 1 resimden 1.
    • Remove the two 8.3 mm Tri-Wing screws hidden under the covers you just removed.
  3. Nintendo Wii Faceplate Replacement: adım 3, 1 resimden 1.
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
  4. Nintendo Wii Faceplate Replacement: adım 4, 1 resimden 1.
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
  5. Nintendo Wii Faceplate Replacement: adım 5, 1 resimden 1.
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
  6. Nintendo Wii Faceplate Replacement: adım 6, 2 resimden 1. Nintendo Wii Faceplate Replacement: adım 6, 2 resimden 2.
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
Sonuç
22 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Any more to do if pressing the on button does nothing, its still red power light?
Kyrre - Yanıt
Tanks for this guide Btw
Kyrre - Yanıt
Thanks for the guide, I just wish it continued with replacing the components within the faceplate, as I wanted to replace the white shell. Still helpful though!
Cynthia - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 61
Son 30 gün: 342
Her zaman: 53,295
