Ana içeriğe geç
Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly
Neye ihtiyacın var
  1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly, Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 1, 3 resimden 1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly, Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 1, 3 resimden 2. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly, Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 1, 3 resimden 3.
    • Remove the battery cover from the remote and batteries inside.
    • Unscrew the four visible screws on the remote. These are Y1 tri-point screws.
  2. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 2, 3 resimden 1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 2, 3 resimden 2. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 2, 3 resimden 3.
    • Use a tool to gently pry apart the white tabs near the top of the controller.
    • Once you open up the remote, there should now be two separate pieces.
    • The tabs may break off, but the remote will still be able to function without them.
  3. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 3, 2 resimden 1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 3, 2 resimden 2.
    • Use a tool or your fingers to remove the speaker piece from the remote.
    • Be careful not to puncture the speaker! This won't render it unuseable BUT will slowly start to sound worse.
  4. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 4, 1 resimden 1.
    • Simply remove the rest of the buttons and the flexible plastic covering.
    • These buttons are very small and easily lost so be sure to keep them organized and close for easy access.
  5. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 5, 3 resimden 1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 5, 3 resimden 2. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 5, 3 resimden 3.
    • Go back to the side of the remote with the motherboard.
    • Gently lift and remove it from the base.
    • Be gentle while pulling out, being sure not to rip off the wires from the rumble motor.
  6. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 6, 2 resimden 1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 6, 2 resimden 2.
    • Pull out the sensor screen.
  7. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 7, 3 resimden 1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 7, 3 resimden 2. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 7, 3 resimden 3.
    • Find the white tabs facing where the sensor screen was.
    • Place a tool under one tab and push up until both tabs pop out of place, and remove the B trigger.
  8. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 8, 2 resimden 1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 8, 2 resimden 2.
    • Use a tool and place it under the rumble motor. Gently lift and remove it from the plastic housing.
    • Be careful while removing. Do not remove any of the wires from the rumble motor.
  9. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 9, 2 resimden 1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 9, 2 resimden 2.
    • To remove the plastic housing, you have to locate the two white tabs. Use your thumbs to gently pull them apart and remove the plastic housing.
    • Remove the rubber button from the plastic housing.
  10. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 10, 2 resimden 1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 10, 2 resimden 2.
    • You should now have all the pieces detached from the Wii remote.
    • You should have all the piece shown in the photos to the left.
  11. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 11, 3 resimden 1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 11, 3 resimden 2. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 11, 3 resimden 3.
    • My partner will now be putting back together the remote while only following the previous instructions I have made.
    • Return the the buttons back to their original spot along with the flexible plastic covering on top.
  12. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 12, 1 resimden 1.
    • Place the rubber button under the plastic housing.
    • Align the two white tabs with the two indents on the sides and slide the plastic housing into place.
    • Put back the rumble motor back to its original spot.
    • Make sure your are putting the white plastic housing on the correct side of the motherboard as it was at the start.
  13. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 13, 2 resimden 1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 13, 2 resimden 2.
    • Return the sensor screen to its spot and slide it back into place.
    • Make sure the sensor screen is facing the right way.
  14. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 14, 2 resimden 1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 14, 2 resimden 2.
    • Place the B trigger back into its spot and click the two white tabs into place.
  15. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 15, 3 resimden 1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 15, 3 resimden 2. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 15, 3 resimden 3.
    • Lay the motherboard on top of the back side of the remote and push down gently til in place.
    • Be sure that the rumble motor is facing down while putting it back in place.
  16. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 16, 3 resimden 1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 16, 3 resimden 2. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 16, 3 resimden 3.
    • Lay the side of the remote with the motherboard on top of the side with the buttons.
    • Align the sides and press together until firmly in place.
    • Screw back in the screws.
  17. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly, Now for the Wii Nunchuk: adım 17, 2 resimden 1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly, Now for the Wii Nunchuk: adım 17, 2 resimden 2.
    • there are two small screws that need to be unscrewed on the bottom of the remote.
  18. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 18, 2 resimden 1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 18, 2 resimden 2.
    • Once the screws are removed, you can pop the top off.
    • Next take the thumb stick and very gently take it off.
  19. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 19, 2 resimden 1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 19, 2 resimden 2.
    • The wire that plugs into the actual remote needs to be pulled apart from the whole nunchuk.
    • The wires can be by its self without the plastic controller housing.
  20. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 20, 2 resimden 1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 20, 2 resimden 2.
    • Flip the wires over and remove the shoulder buttons (white plastic).
    • It'll be easier to slide the other piece out to so make sure to gently slide it out.
  21. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 21, 2 resimden 1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 21, 2 resimden 2.
    • Then remove the plastic that connects the sensor and the shoulder buttons.
  22. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 22, 3 resimden 1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 22, 3 resimden 2. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 22, 3 resimden 3.
    • Now start to attach all of the pieces back starting with the hard plastic first.
    • Make sure not to force the sensor in the spot and slide it upwards.
    • The shoulder buttons are easy to put in but don't push it.
    • Example of my partner.
  23. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 23, 2 resimden 1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 23, 2 resimden 2.
    • Be careful when putting the wires back in because they are easy to fall out.
  24. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 24, 2 resimden 1. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 24, 2 resimden 2.
    • She then attaches the analog stick to get it going again.
  25. Nintendo Wii Remote & Wii Nunchuk Accessory Disassembly/Reassembly: adım 25, 1 resimden 1.
    • Lastly she easily popped the top back on and screwed the bottom to back on and got it to work as it used to.
Sonuç
23 farklı kişi bu kılavuzu tamamladı.
Linda Bowers
859 İtibar
1 Kılavuz yazıldı
6 Yorum
Great guide! I took one of my remotes apart some years ago. Now, with fresh tri-wing driver in hand, I am ready to reassemble the thing. Problem: where to solder the green ground? It currently is fused to the nunchuk connector housing, but where does the other end go??? Wish I'd noted that, back then
K. Lehnert - Yanıt
Very accurate guide! I was able to clear debris between the buttons with ease.
Aiden - Yanıt
Hello do you have tutorials for unassembly nunchuck's connector please?
Patrick WAI KHAI SONE - Yanıt
Thank you ! My A button registered the click half the time : turns out it had corrosion, now it works like a charm !
CreaZyp! - Yanıt
I want to take the springs off the wii Remotes Back. The ones that are still in the back during Step 10.
Emmanuel Ladejobi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 18
Son 7 gün: 72
Son 30 gün: 361
Her zaman: 42,100
