Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Disassembling the case requires removing screws under the batteries. Removing anything inside requires this guide.
Neye ihtiyacın var
Flip the Wii Remote over so the battery cover faces you.
Push up on the bottom tab.
Remove the battery cover.
36 farklı kişi bu kılavuzu tamamladı.
4 Yorum
Worked! Had to solder the tab to contact the battery which had broken. Saved $50.00.
The Tools section lists a Tri-Point Y1 Screwdriver but the guide mentions a Tri-Wing Y1 Screwdriver. This could cause people to purchase the wrong item.
iFixit’s guides seem to be based on the original Wii controller, model RVL-003. I’m not sure if Nintendo has changed fasteners for subsequent versions but the Wii MotionPlus Controller, model RVL-036, uses a Tri-Wing Y0 screw.
