Ana içeriğe geç
Nintendo Wii Remote Main Buttons Replacement
Neye ihtiyacın var
  1. Nintendo Wii Remote Main Buttons Replacement, Front Cover Plate and Batteries: adım 1, 2 resimden 1. Nintendo Wii Remote Main Buttons Replacement, Front Cover Plate and Batteries: adım 1, 2 resimden 2.
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    FixBot'a Sor
    Yorum Ekle
  2. Nintendo Wii Remote Main Buttons Replacement: adım 2, 1 resimden 1.
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
    FixBot'a Sor
    Yorum Ekle
  3. Nintendo Wii Remote Main Buttons Replacement: adım 3, 1 resimden 1.
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
    FixBot'a Sor
    Yorum Ekle
  4. Nintendo Wii Remote Main Buttons Replacement: adım 4, 2 resimden 1. Nintendo Wii Remote Main Buttons Replacement: adım 4, 2 resimden 2.
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    FixBot'a Sor
    Yorum Ekle
  5. Nintendo Wii Remote Main Buttons Replacement, Main Buttons: adım 5, 2 resimden 1. Nintendo Wii Remote Main Buttons Replacement, Main Buttons: adım 5, 2 resimden 2.
    • Working on the inside of the front cover, peel off the three rubber pads covering the buttons.
    FixBot'a Sor
    Yorum Ekle
  6. Nintendo Wii Remote Main Buttons Replacement: adım 6, 1 resimden 1.
    • Flip over the cover, allowing the buttons to fall into your hand.
    • Be ready to catch all the buttons, some are very small. If a button does not fall out apply gentle pressure from behind.
    • When reassembling, put each plastic button in its allocated slot. Each button only fits snugly in one slot.
    • The best option for you is rotate the Wii Controller by 180°. If you obey this note, the small parts wont fall off and then you can remove the buttons.
    FixBot'a Sor
    Yorum Ekle
Sonuç
27 farklı kişi bu kılavuzu tamamladı.
Emily
2.015 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-44, Amido Spring 2013 Cal Poly, Team 3-44, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S3G44
4 Üyeler
29 adet Kılavuz yazıldı
5Kılavuz Yorumları
Where did you get your replacement buttons? I can't find them online anywhere...
devannedloss - Yanıt Paylaş
Me too, can’t find them.
Michael Velten - Yanıt Paylaş
2024 and can't find them online ANYWHERE! I'm hoping a WiiUDpad fits on the wiimote. You'd think there'd be a bunch of wiimote shells of different colours available everywhere online, but they're nowhere to be found
how frustrating!
MartianIsotopes - Yanıt Paylaş
Vinted is full of them. Although some people ask wayyy too much for them!
Sophie Nicholson - Yanıt Paylaş
Yo tampoco los encuentro por ninguna parte
kinoto taller - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 18
Son 7 gün: 79
Son 30 gün: 353
Her zaman: 49,578
