Ana içeriğe geç
Nintendo Wii Remote Motherboard Replacement
Neye ihtiyacın var
  1. Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: adım 1, 2 resimden 1. Nintendo Wii Remote Motherboard Replacement, Front Cover Plate and Batteries: adım 1, 2 resimden 2.
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    FixBot'a Sor
    Yorum Ekle
  2. Nintendo Wii Remote Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
    FixBot'a Sor
    Yorum Ekle
  3. Nintendo Wii Remote Motherboard Replacement: adım 3, 1 resimden 1.
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
    FixBot'a Sor
    Yorum Ekle
  4. Nintendo Wii Remote Motherboard Replacement: adım 4, 2 resimden 1. Nintendo Wii Remote Motherboard Replacement: adım 4, 2 resimden 2.
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    FixBot'a Sor
    Yorum Ekle
  5. Nintendo Wii Remote Motherboard Replacement, Motherboard: adım 5, 2 resimden 1. Nintendo Wii Remote Motherboard Replacement, Motherboard: adım 5, 2 resimden 2.
    • Using the connector port, gently lift the motherboard about 2 cm from the base.
    • Electrostatic discharge may damage the device. Be careful and avoid touching the electronic components as much as possible.
    FixBot'a Sor
    Yorum Ekle
  6. Nintendo Wii Remote Motherboard Replacement: adım 6, 2 resimden 1. Nintendo Wii Remote Motherboard Replacement: adım 6, 2 resimden 2.
    • Grasp the edges of the motherboard and pull it straight away from the case.
    FixBot'a Sor
    Yorum Ekle
Sonuç
36 farklı kişi bu kılavuzu tamamladı.
Emily
2.015 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-44, Amido Spring 2013 Cal Poly, Team 3-44, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S3G44
4 Üyeler
35 adet Kılavuz yazıldı
7Kılavuz Yorumları
Where do you find a motherboard and how much do they typically cost?
Jeff - Yanıt Paylaş
This is useless because you can't just buy a motherboard. May as well buy a new remote for $20
Lisa Cole - Yanıt Paylaş
Where can i buy a brand new and original (not fake of course) wii remote for $20?
arttitudesign - Yanıt Paylaş
You can buy a first party Wii remote plus for under $50 at Walmart, best buy, or online on Amazon or on Nintendos website
Darren Woloshyn - Yanıt Paylaş
What is the dimension is the motherboard? I want to make a custom motherboard for the housing but I haven't managed to get int the wiimote yet as I am waiting for my tri screwdriver
Michael baldwin - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 17
Son 7 gün: 83
Son 30 gün: 365
Her zaman: 40,536
