Ana içeriğe geç
Nintendo Wii Remote Sensor Screen Replacement
Neye ihtiyacın var
  1. Nintendo Wii Remote Sensor Screen Replacement, Front Cover Plate and Batteries: adım 1, 2 resimden 1. Nintendo Wii Remote Sensor Screen Replacement, Front Cover Plate and Batteries: adım 1, 2 resimden 2.
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    FixBot'a Sor
    Yorum Ekle
  2. Nintendo Wii Remote Sensor Screen Replacement: adım 2, 1 resimden 1.
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
    FixBot'a Sor
    Yorum Ekle
  3. Nintendo Wii Remote Sensor Screen Replacement: adım 3, 1 resimden 1.
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
    FixBot'a Sor
    Yorum Ekle
  4. Nintendo Wii Remote Sensor Screen Replacement: adım 4, 2 resimden 1. Nintendo Wii Remote Sensor Screen Replacement: adım 4, 2 resimden 2.
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    FixBot'a Sor
    Yorum Ekle
  5. Nintendo Wii Remote Sensor Screen Replacement, Sensor Screen: adım 5, 3 resimden 1. Nintendo Wii Remote Sensor Screen Replacement, Sensor Screen: adım 5, 3 resimden 2. Nintendo Wii Remote Sensor Screen Replacement, Sensor Screen: adım 5, 3 resimden 3.
    • Tilt the remote, without the front cover plate, upward so the handle strap is at the bottom and the black screen is facing you.
    • Grip the outward edge of the screen with your fingers.
    • Gently, pull the screen straight outward from its housing. The screen will slide directly out.
    FixBot'a Sor
    Yorum Ekle
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Emily
2.015 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-44, Amido Spring 2013 Cal Poly, Team 3-44, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S3G44
4 Üyeler
29 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where can the screen be purchased??
cutsiepie6480 - Yanıt Paylaş
how is this moderate difficulty
Sqwerks - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 104
Son 30 gün: 396
Her zaman: 27,832
