Ana içeriğe geç
Nintendo Wii Remote Speaker Replacement
Neye ihtiyacın var
  1. Nintendo Wii Remote Speaker Replacement, Front Cover Plate and Batteries: adım 1, 2 resimden 1. Nintendo Wii Remote Speaker Replacement, Front Cover Plate and Batteries: adım 1, 2 resimden 2.
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
    FixBot'a Sor
    Yorum Ekle
  2. Nintendo Wii Remote Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
    FixBot'a Sor
    Yorum Ekle
  3. Nintendo Wii Remote Speaker Replacement: adım 3, 1 resimden 1.
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
    FixBot'a Sor
    Yorum Ekle
  4. Nintendo Wii Remote Speaker Replacement: adım 4, 2 resimden 1. Nintendo Wii Remote Speaker Replacement: adım 4, 2 resimden 2.
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    FixBot'a Sor
    Yorum Ekle
  5. Nintendo Wii Remote Speaker Replacement, Speaker: adım 5, 3 resimden 1. Nintendo Wii Remote Speaker Replacement, Speaker: adım 5, 3 resimden 2. Nintendo Wii Remote Speaker Replacement, Speaker: adım 5, 3 resimden 3.
    • Place the plastic opening tool between the edge of the speaker and the wii remote.
    • Gently lift the speaker out of the body of the Wii remote.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Emily
2.015 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-44, Amido Spring 2013 Cal Poly, Team 3-44, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S3G44
4 Üyeler
35 adet Kılavuz yazıldı
2Kılavuz Yorumları
Thank you, u help me to fix it.
joon lew - Yanıt Paylaş
That's cool and all, but what speaker am I supposed to buy?
Shadow - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 32
Son 30 gün: 119
Her zaman: 9,662
