Ana içeriğe geç
Nintendo Wii U Button Replacement
Neye ihtiyacın var
  1. Nintendo Wii U Button Replacement, Button Replacement: adım 1, 2 resimden 1. Nintendo Wii U Button Replacement, Button Replacement: adım 1, 2 resimden 2.
    • You will first need to find all the screws hidden underneath the black (or white) square stickers. They are all located on the bottom side of the Wii U.
    • Use a spudger to remove the stickers if it is difficult to peel off with your fingers.
  2. Nintendo Wii U Button Replacement: adım 2, 1 resimden 1.
    • Remove the five Phillips #0 screws.
    • Remove the four Tri-Wing Y1 screws.
  3. Nintendo Wii U Button Replacement: adım 3, 2 resimden 1. Nintendo Wii U Button Replacement: adım 3, 2 resimden 2.
    • Remove the CMOS battery door on the left side of the console.
    • Once the door is removed, remove the three Phillips #0 screws.
  4. Nintendo Wii U Button Replacement: adım 4, 3 resimden 1. Nintendo Wii U Button Replacement: adım 4, 3 resimden 2. Nintendo Wii U Button Replacement: adım 4, 3 resimden 3.
    • Gently pry off the top lid of the Wii U.
  5. Nintendo Wii U Button Replacement: adım 5, 3 resimden 1. Nintendo Wii U Button Replacement: adım 5, 3 resimden 2. Nintendo Wii U Button Replacement: adım 5, 3 resimden 3.
    • Rotate the device so that the front plate is facing you.
    • Remove the two Phillips #1 screws.
  6. Nintendo Wii U Button Replacement: adım 6, 3 resimden 1. Nintendo Wii U Button Replacement: adım 6, 3 resimden 2. Nintendo Wii U Button Replacement: adım 6, 3 resimden 3.
    • Remove the ribbon cable and separate the front plate from the main console.
  7. Nintendo Wii U Button Replacement: adım 7, 1 resimden 1.
    • Remove the three Phillips #1 screws.
  8. Nintendo Wii U Button Replacement: adım 8, 1 resimden 1.
    • Once unscrewed, remove the black braces that hold the power button, eject button, and sync button in place.
  9. Nintendo Wii U Button Replacement: adım 9, 1 resimden 1.
    • Remove the desired button(s).
Sonuç
Emily Vasquez
884 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-2, Leahy Spring 2016 USF Tampa, Team 1-2, Leahy Spring 2016 üyesi
USFT-LEAHY-S16S1G2
3 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Anyone know what that ribbon cable is in step 6? Just regular 9 pin?
Lugi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 24
Son 30 gün: 85
Her zaman: 4,501
