Ana içeriğe geç
Nintendo Wii U Console Outer Case Replacement
Neye ihtiyacın var
  1. Nintendo Wii U Console Outer Case Replacement, Console Outer Case: adım 1, 1 resimden 1.
    • With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
    • Three 5.1mm Phillips #000 screws
    • Two 6.1mm Tri-wing Y0 screws
    • One 13.2mm Tri-wing Y1 screw
  2. Nintendo Wii U Console Outer Case Replacement: adım 2, 1 resimden 1.
    • Rotate the console 180 degrees so that the exhaust vents are facing you.
    • Remove the two 7.1mm Phillips #00 screws.
  3. Nintendo Wii U Console Outer Case Replacement: adım 3, 2 resimden 1. Nintendo Wii U Console Outer Case Replacement: adım 3, 2 resimden 2.
    • On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
  4. Nintendo Wii U Console Outer Case Replacement: adım 4, 1 resimden 1.
    • On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
  5. Nintendo Wii U Console Outer Case Replacement: adım 5, 3 resimden 1. Nintendo Wii U Console Outer Case Replacement: adım 5, 3 resimden 2. Nintendo Wii U Console Outer Case Replacement: adım 5, 3 resimden 3.
    • On the back of the console, lift up and release the main top cover.
Sonuç
27 farklı kişi bu kılavuzu tamamladı.
Kim Arre
4.918 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-20, Forte Winter 2013 Cal Poly, Team 17-20, Forte Winter 2013 üyesi
CPSU-FORTE-W13S17G20
5 Üyeler
38 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 75
Son 30 gün: 379
Her zaman: 32,128
