Ana içeriğe geç
Nintendo Wii U DVD Drive Replacement
Neye ihtiyacın var
  1. Nintendo Wii U DVD Drive Replacement, Console Outer Case: adım 1, 1 resimden 1.
    • With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
    • Three 5.1mm Phillips #000 screws
    • Two 6.1mm Tri-wing Y0 screws
    • One 13.2mm Tri-wing Y1 screw
  2. Nintendo Wii U DVD Drive Replacement: adım 2, 1 resimden 1.
    • Rotate the console 180 degrees so that the exhaust vents are facing you.
    • Remove the two 7.1mm Phillips #00 screws.
  3. Nintendo Wii U DVD Drive Replacement: adım 3, 2 resimden 1. Nintendo Wii U DVD Drive Replacement: adım 3, 2 resimden 2.
    • On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
  4. Nintendo Wii U DVD Drive Replacement: adım 4, 1 resimden 1.
    • On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
  5. Nintendo Wii U DVD Drive Replacement: adım 5, 3 resimden 1. Nintendo Wii U DVD Drive Replacement: adım 5, 3 resimden 2. Nintendo Wii U DVD Drive Replacement: adım 5, 3 resimden 3.
    • On the back of the console, lift up and release the main top cover.
  6. Nintendo Wii U DVD Drive Replacement, Front Faceplate: adım 6, 2 resimden 1. Nintendo Wii U DVD Drive Replacement, Front Faceplate: adım 6, 2 resimden 2.
    • Rotate the device so that the front plate is facing you.
    • On each side of the console, remove the 3.5mm Phillips #0 screw connecting the DVD drive to the faceplate.
  7. Nintendo Wii U DVD Drive Replacement: adım 7, 1 resimden 1.
    • Rotate the device so that the front plate is on the right side and the ribbon cable is visible.
    • The ribbon cable is connected to the system by a latch which holds in the blue tab. Flip this latch up to unlock it.
    • Lift up on the blue tab to release the ribbon cable.
  8. Nintendo Wii U DVD Drive Replacement: adım 8, 1 resimden 1.
    • Remove the front faceplate.
  9. Nintendo Wii U DVD Drive Replacement, DVD Drive: adım 9, 1 resimden 1.
    • On each side of the DVD drive, remove the two 4.6mm Phillips #0 mounting screws.
  10. Nintendo Wii U DVD Drive Replacement: adım 10, 2 resimden 1. Nintendo Wii U DVD Drive Replacement: adım 10, 2 resimden 2.
    • Rotate the device so that the DVD slot is visible.
    • A ribbon cable is attached to the bottom right side of the DVD drive. The ribbon cable can rip if it isn't removed properly.
    • Lift the DVD drive out of the mount and turn over to the right so it lies like a book.
    • Use a spudger to release the ribbon cable.
  11. Nintendo Wii U DVD Drive Replacement: adım 11, 1 resimden 1.
    • Remove the CD drive.
Sonuç
50 farklı kişi bu kılavuzu tamamladı.
Kim Arre
4.831 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-20, Forte Winter 2013 Cal Poly, Team 17-20, Forte Winter 2013 üyesi
CPSU-FORTE-W13S17G20
5 Üyeler
33 adet Kılavuz yazıldı
48 Yorum
I've done with twice with two different drives ordered on Ebay, and keep getting the same error code (160-1402). Is the place I'm buying from selling bad drives, or is there something else that needs to be done after? It goes back to working when I put my old one back in, so I know I'm physically doing it correctly.
Brad Senatore - Yanıt
Update : For anybody else having this problem, you have to change out the logic board from your old drive to the new one. Pain in the neck, but works!
Brad Senatore -
What do you mean by change out the logic board?
gingindua -
the logic board is inside the disk drive. Remove it and replace it into the new disk drive. This is the same on the Xbox and Playstation
rehrnsberger -
Did an update it failed rebooted and now get a 160-1402. With the DVD drive cover off the Spindle isnt moving. Suspect Drive would seem 160-XXXX is DVD Drive related Errors
Ben Uwins - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 75
Son 30 gün: 343
Her zaman: 75,280
