Ana içeriğe geç
Nintendo Wii U GamePad Analog Stick Replacement
Neye ihtiyacın var
  1. Nintendo Wii U GamePad Analog Stick Replacement, Battery: adım 1, 2 resimden 1. Nintendo Wii U GamePad Analog Stick Replacement, Battery: adım 1, 2 resimden 2.
    • Face the GamePad down and unscrew the two 4.7 mm Phillips #00 screws which are attached to the battery cover.
    • Lift up and remove the battery cover.
  2. Nintendo Wii U GamePad Analog Stick Replacement: adım 2, 3 resimden 1. Nintendo Wii U GamePad Analog Stick Replacement: adım 2, 3 resimden 2. Nintendo Wii U GamePad Analog Stick Replacement: adım 2, 3 resimden 3.
    • With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it.
    • Pull upwards from the bottom of the battery to release it.
  3. Nintendo Wii U GamePad Analog Stick Replacement, Back Panel: adım 3, 3 resimden 1. Nintendo Wii U GamePad Analog Stick Replacement, Back Panel: adım 3, 3 resimden 2. Nintendo Wii U GamePad Analog Stick Replacement, Back Panel: adım 3, 3 resimden 3.
    • Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
    • Lift up the back plate.
    • The back plate is still connected by a cable to the motherboard.
  4. Nintendo Wii U GamePad Analog Stick Replacement: adım 4, 2 resimden 1. Nintendo Wii U GamePad Analog Stick Replacement: adım 4, 2 resimden 2.
    • Unplug the connector that connects the back plate to the motherboard.
    • Remove the back panel.
  5. Nintendo Wii U GamePad Analog Stick Replacement, Analog Stick: adım 5, 2 resimden 1. Nintendo Wii U GamePad Analog Stick Replacement, Analog Stick: adım 5, 2 resimden 2.
    • Take out the left and right shoulder buttons in the upper corners.
    • Remove the ZR and ZL trigger buttons by lifting up and sliding outward.
  6. Nintendo Wii U GamePad Analog Stick Replacement: adım 6, 2 resimden 1. Nintendo Wii U GamePad Analog Stick Replacement: adım 6, 2 resimden 2.
    • Remove the top rubber cover by pulling it off of its mounts to access one of the mounting screws.
    • Remove the four 5.2mm Phillips #0 screws.
  7. Nintendo Wii U GamePad Analog Stick Replacement: adım 7, 2 resimden 1. Nintendo Wii U GamePad Analog Stick Replacement: adım 7, 2 resimden 2.
    • Use a spudger to lift the tab which releases the blue ribbon cable.
    • Remove the analog stick and button cover.
  8. Nintendo Wii U GamePad Analog Stick Replacement: adım 8, 1 resimden 1.
    • Use your thumb and push the connector towards the rightmost edge to disconnect the analog stick cable connector.
  9. Nintendo Wii U GamePad Analog Stick Replacement: adım 9, 2 resimden 1. Nintendo Wii U GamePad Analog Stick Replacement: adım 9, 2 resimden 2.
    • Remove the two 9.0mm Tri-wing Y0 screws.
    • Lift out the analog stick.
Sonuç
86 farklı kişi bu kılavuzu tamamladı.
Kim Arre
5.247 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-20, Forte Winter 2013 Cal Poly, Team 17-20, Forte Winter 2013 üyesi
CPSU-FORTE-W13S17G20
5 Üyeler
40 adet Kılavuz yazıldı
35Kılavuz Yorumları
where can i find replacement analogs for wiiu gamepad and wiiu procontoller?
Victor Torres - Yanıt
www.ebay.com
mhuntersr -
They are available at ebay.com Cost around 7,50 $ Left & Right (different - look what you need). Comes all from china or hong Kong but Quality is 1A (so far i can tell).
Frederik Rischmann -
Bump previous question because dogs seem to enjoy their texture.
maskedpainter - Yanıt
Has anyone tried this?
http://dx.com/p/replacement-3d-analog-st...
I know it says for the pro controller. But based from the images, the pins could be compatible.
wandererwk - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 119
Son 30 gün: 547
Her zaman: 106,319
