Ana içeriğe geç
Nintendo Wii U GamePad Directional Pad Buttons Replacement
Neye ihtiyacın var
  1. Nintendo Wii U GamePad Directional Pad Buttons Replacement, Back Panel: adım 1, 3 resimden 1. Nintendo Wii U GamePad Directional Pad Buttons Replacement, Back Panel: adım 1, 3 resimden 2. Nintendo Wii U GamePad Directional Pad Buttons Replacement, Back Panel: adım 1, 3 resimden 3.
    • Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
    • Lift up the back plate.
    • The back plate is still connected by a cable to the motherboard.
  2. Nintendo Wii U GamePad Directional Pad Buttons Replacement: adım 2, 2 resimden 1. Nintendo Wii U GamePad Directional Pad Buttons Replacement: adım 2, 2 resimden 2.
    • Unplug the connector that connects the back plate to the motherboard.
    • Remove the back panel.
  3. Nintendo Wii U GamePad Directional Pad Buttons Replacement, Analog Stick: adım 3, 2 resimden 1. Nintendo Wii U GamePad Directional Pad Buttons Replacement, Analog Stick: adım 3, 2 resimden 2.
    • Take out the left and right shoulder buttons in the upper corners.
    • Remove the ZR and ZL trigger buttons by lifting up and sliding outward.
  4. Nintendo Wii U GamePad Directional Pad Buttons Replacement: adım 4, 2 resimden 1. Nintendo Wii U GamePad Directional Pad Buttons Replacement: adım 4, 2 resimden 2.
    • Remove the top rubber cover by pulling it off of its mounts to access one of the mounting screws.
    • Remove the four 5.2mm Phillips #0 screws.
  5. Nintendo Wii U GamePad Directional Pad Buttons Replacement: adım 5, 2 resimden 1. Nintendo Wii U GamePad Directional Pad Buttons Replacement: adım 5, 2 resimden 2.
    • Use a spudger to lift the tab which releases the blue ribbon cable.
    • Remove the analog stick and button cover.
  6. Nintendo Wii U GamePad Directional Pad Buttons Replacement: adım 6, 1 resimden 1.
    • Use your thumb and push the connector towards the rightmost edge to disconnect the analog stick cable connector.
  7. Nintendo Wii U GamePad Directional Pad Buttons Replacement: adım 7, 2 resimden 1. Nintendo Wii U GamePad Directional Pad Buttons Replacement: adım 7, 2 resimden 2.
    • Remove the two 9.0mm Tri-wing Y0 screws.
    • Lift out the analog stick.
  8. Nintendo Wii U GamePad Directional Pad Buttons Replacement, Directional Pad Buttons: adım 8, 2 resimden 1. Nintendo Wii U GamePad Directional Pad Buttons Replacement, Directional Pad Buttons: adım 8, 2 resimden 2.
    • Lift up and remove the rubber cover for the directional pad.
    • Remove the directional pad buttons.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Kim Arre
5.017 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-20, Forte Winter 2013 Cal Poly, Team 17-20, Forte Winter 2013 üyesi
CPSU-FORTE-W13S17G20
5 Üyeler
39 adet Kılavuz yazıldı
Bir Yorum
Where can you find the blue ribbon mentioned in step 5, for the buttons at?
Eric - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 28
Son 30 gün: 148
Her zaman: 20,406
