Ana içeriğe geç
Nintendo Wii U Pro Controller D-Pad Replacement
Neye ihtiyacın var
  1. Nintendo Wii U Pro Controller D-Pad Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the controller over to reveal the battery cover.
    • Use the J000 screwdriver to remove the screw that secures the battery cover.
  2. Nintendo Wii U Pro Controller D-Pad Replacement: adım 2, 2 resimden 1. Nintendo Wii U Pro Controller D-Pad Replacement: adım 2, 2 resimden 2.
    • Remove the battery from the controller by inserting the plastic spudger into the small gap on the bottom right of the battery.
    • Use the spudger as a lever to pry up and remove the battery from the compartment.
  3. Nintendo Wii U Pro Controller D-Pad Replacement, Joystick: adım 3, 1 resimden 1.
    • Remove the eight 5.5 mm Y0 screws.
  4. Nintendo Wii U Pro Controller D-Pad Replacement: adım 4, 2 resimden 1. Nintendo Wii U Pro Controller D-Pad Replacement: adım 4, 2 resimden 2.
    • Now that you have removed all of the screws, carefully separate and remove the bottom half of the controller shell from the top half.
    • If you feel any resistance when pulling the shells apart, use a spudger to separate the left and right trigger contact assemblies from the bottom shell.
  5. Nintendo Wii U Pro Controller D-Pad Replacement: adım 5, 1 resimden 1.
    • Move the right trigger and sensor out of the way.
    • Remove the 4 mm JIS #0 screw.
  6. Nintendo Wii U Pro Controller D-Pad Replacement: adım 6, 1 resimden 1.
    • Move the left trigger and sensor out of the way.
  7. Nintendo Wii U Pro Controller D-Pad Replacement: adım 7, 1 resimden 1.
    • Remove the joysticks and motherboard from the controller’s shell.
  8. Nintendo Wii U Pro Controller D-Pad Replacement: adım 8, 1 resimden 1.
    • Carefully pull the rubber thumbsticks off of the electronic bearings to remove the joysticks.
  9. Nintendo Wii U Pro Controller D-Pad Replacement, D-Pad: adım 9, 1 resimden 1.
    • Locate the two 4 mm motherboard screws, shown circled in red, with the J0 screwdriver.
  10. Nintendo Wii U Pro Controller D-Pad Replacement: adım 10, 1 resimden 1.
    • Remove the motherboard and connected components. The rubber pad of the D-Pad is indicated in the image by the red arrow.
  11. Nintendo Wii U Pro Controller D-Pad Replacement: adım 11, 1 resimden 1.
    • Remove the rubber pad and D-Pad button. The D-Pad can be replaced by the new D-Pad or be cleaned to improve condition.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jesse Burton
586 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-2, Harley Fall 2015 IUPUI, Team 2-2, Harley Fall 2015 üyesi
IUPUI-HARLEY-F15S2G2
4 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 42
Her zaman: 4,443
