Giriş
We pick up where we left off after removing the joysticks. To reach the D-Pad, we will first remove the motherboard.
Neye ihtiyacın var
Turn the controller over to reveal the battery cover.
Use the J000 screwdriver to remove the screw that secures the battery cover.
Now that you have removed all of the screws, carefully separate and remove the bottom half of the controller shell from the top half.
If you feel any resistance when pulling the shells apart, use a spudger to separate the left and right trigger contact assemblies from the bottom shell.
Locate the two 4 mm motherboard screws, shown circled in red, with the J0 screwdriver.
3 farklı kişi bu kılavuzu tamamladı.
