Ana içeriğe geç
Nintendo Wii mini Power Board Replacement
Neye ihtiyacın var
  1. Nintendo Wii mini Power Board Replacement, Unscrew the Bottom: adım 1, 2 resimden 1. Nintendo Wii mini Power Board Replacement, Unscrew the Bottom: adım 1, 2 resimden 2.
    • Remove the two rubber feet at the back of the console to reveal the hidden screws.
    • Remove the four 6mm Phillips #0 screws.
  2. Nintendo Wii mini Power Board Replacement, Remove the Cover: adım 2, 3 resimden 1. Nintendo Wii mini Power Board Replacement, Remove the Cover: adım 2, 3 resimden 2. Nintendo Wii mini Power Board Replacement, Remove the Cover: adım 2, 3 resimden 3.
    • Turn the Wii mini right-side up. Then run a plastic opening tool around the middle edge of the console to loosen the top piece.
    • Gently lift the top piece of the console and set it aside.
  3. Nintendo Wii mini Power Board Replacement, Power Board: adım 3, 3 resimden 1. Nintendo Wii mini Power Board Replacement, Power Board: adım 3, 3 resimden 2. Nintendo Wii mini Power Board Replacement, Power Board: adım 3, 3 resimden 3.
    • Using your fingers, slide out the blue ribbon cable from the the top of the power board.
    • Using a Phillips #0 Screwdriver, unscrew the two 4mm screws at the top and bottom of the power board.
  4. Nintendo Wii mini Power Board Replacement: adım 4, 2 resimden 1. Nintendo Wii mini Power Board Replacement: adım 4, 2 resimden 2.
    • Using your fingers, gently pull the pin connector to disconnect the power board from the disc drive.
  5. Nintendo Wii mini Power Board Replacement: adım 5, 2 resimden 1. Nintendo Wii mini Power Board Replacement: adım 5, 2 resimden 2.
    • Lift the power board from the console and set it aside.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kristin Anderson
963 İtibar
5 adet Kılavuz yazıldı
Ekip
UWT Liner: Group 5 UWT Liner: Group 5 üyesi
Community
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 1,821
