Ana içeriğe geç
Nissan Versa Note Media Display System Replacement
Neye ihtiyacın var
  1. Nissan Versa Note Media Display System Replacement, Media Display System: adım 1, 1 resimden 1.
    • Ensure that the car is turned off.
  2. Nissan Versa Note Media Display System Replacement: adım 2, 1 resimden 1.
    • Pull on the switch for indoor/outdoor air to remove it.
  3. Nissan Versa Note Media Display System Replacement: adım 3, 2 resimden 1. Nissan Versa Note Media Display System Replacement: adım 3, 2 resimden 2.
    • Use a spudger (or an old credit card) to gently pry the front panel away from the rest of the dash.
    • After wedging the parts apart you will see a gap.
  4. Nissan Versa Note Media Display System Replacement: adım 4, 3 resimden 1. Nissan Versa Note Media Display System Replacement: adım 4, 3 resimden 2. Nissan Versa Note Media Display System Replacement: adım 4, 3 resimden 3.
    • Using your fingers, start from the top of the panel and move down on either side to pry the panel open.
  5. Nissan Versa Note Media Display System Replacement: adım 5, 2 resimden 1. Nissan Versa Note Media Display System Replacement: adım 5, 2 resimden 2.
    • Once the panel is free from the dash, flip it over to expose the cables connected to it.
  6. Nissan Versa Note Media Display System Replacement: adım 6, 3 resimden 1. Nissan Versa Note Media Display System Replacement: adım 6, 3 resimden 2. Nissan Versa Note Media Display System Replacement: adım 6, 3 resimden 3.
    • Remove the top cable by simply squeezing the end and pulling it out of its socket.
    • Use a spudger to push down on the tab of the bottom cable and remove it.
  7. Nissan Versa Note Media Display System Replacement: adım 7, 3 resimden 1. Nissan Versa Note Media Display System Replacement: adım 7, 3 resimden 2. Nissan Versa Note Media Display System Replacement: adım 7, 3 resimden 3.
    • The front panel is now completely free from the dash and can be set aside.
    • Using a Phillips #3 screwdriver, remove the two screws on either side of the media system.
  8. Nissan Versa Note Media Display System Replacement: adım 8, 2 resimden 1. Nissan Versa Note Media Display System Replacement: adım 8, 2 resimden 2.
    • Carefully pull out the media system and turn it over so that the cables on its rear are visible.
    • Use your hands to pinch the tabs and gently pull out each cable.
  9. Nissan Versa Note Media Display System Replacement: adım 9, 3 resimden 1. Nissan Versa Note Media Display System Replacement: adım 9, 3 resimden 2. Nissan Versa Note Media Display System Replacement: adım 9, 3 resimden 3.
    • Now the media system is completely free from the car.
    • Using a T10 Torx screwdriver, unscrew the four screws on either side of the media system.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 17
Son 30 gün: 88
Her zaman: 3,515
