Ana içeriğe geç
Nite Ize Inova Microlight Battery Replacement
Neye ihtiyacın var
  1. Nite Ize Inova Microlight Battery Replacement, Case Removal: adım 1, 2 resimden 1. Nite Ize Inova Microlight Battery Replacement, Case Removal: adım 1, 2 resimden 2.
    • Insert the plastic opening tool into the seam of the device.
  2. Nite Ize Inova Microlight Battery Replacement, Battery Removal: adım 2, 3 resimden 1. Nite Ize Inova Microlight Battery Replacement, Battery Removal: adım 2, 3 resimden 2. Nite Ize Inova Microlight Battery Replacement, Battery Removal: adım 2, 3 resimden 3.
    • Squeeze the top battery using a tweezer and pull the battery away from the light bulb.
    • Repeat this step for the bottom remaining battery.
    • Do not pull up on the battery as this will bend the metal contact.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jennifer Tabadero
526 İtibar
3 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-1, Bruce Fall 2014 CSU Fullerton, Team 2-1, Bruce Fall 2014 üyesi
CSUF-BRUCE-F14S2G1
3 Üyeler
Bir Yorum
There is another Inova flashlight design that involves removing two Phillips type screw heads that are VERY TINY. I am able to unscrew one, but not the other, so am stuck and unable to replace the batteries.
Chrystin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 53
Her zaman: 5,604
