Ana içeriğe geç
Nite Ize Inova Microlight Casing Replacement
Neye ihtiyacın var
  1. Nite Ize Inova Microlight Casing Replacement, Case Removal: adım 1, 2 resimden 1. Nite Ize Inova Microlight Casing Replacement, Case Removal: adım 1, 2 resimden 2.
    • Insert the plastic opening tool into the seam of the device.
  2. Nite Ize Inova Microlight Casing Replacement, Battery Removal: adım 2, 3 resimden 1. Nite Ize Inova Microlight Casing Replacement, Battery Removal: adım 2, 3 resimden 2. Nite Ize Inova Microlight Casing Replacement, Battery Removal: adım 2, 3 resimden 3.
    • Squeeze the top battery using a tweezer and pull the battery away from the light bulb.
    • Repeat this step for the bottom remaining battery.
    • Do not pull up on the battery as this will bend the metal contact.
  3. Nite Ize Inova Microlight Casing Replacement, LED Light Removal: adım 3, 3 resimden 1. Nite Ize Inova Microlight Casing Replacement, LED Light Removal: adım 3, 3 resimden 2. Nite Ize Inova Microlight Casing Replacement, LED Light Removal: adım 3, 3 resimden 3.
    • Place the plastic opening tool below the LED lamp and push away from the device until you hear a click.
    • Continue to remove the LED lamp the with your fingers.
  4. Nite Ize Inova Microlight Casing Replacement, Logic Board Removal: adım 4, 1 resimden 1.
    • Place the plastic opening tool behind the logic board and bend away from the casing
  5. Nite Ize Inova Microlight Casing Replacement, Logic Board Removal: adım 5, 1 resimden 1.
    • The logic board will pop out with ease.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jennifer Tabadero
526 İtibar
3 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-1, Bruce Fall 2014 CSU Fullerton, Team 2-1, Bruce Fall 2014 üyesi
CSUF-BRUCE-F14S2G1
3 Üyeler
1Rehber Yorum
Great Job! found this one night while looking at my little blue light. Great tools, photos. +30
4-16-2017
F3ND1MUS - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 22
Her zaman: 914
