Ana içeriğe geç
Nixon Mission Android Wear Battery Replacement
Neye ihtiyacın var
  1. Nixon Mission Android Wear Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Remove 4 4.5mm Phillips head screws from back side of watch using PH00 Phillips head.
  2. Nixon Mission Android Wear Battery Replacement: adım 2, 1 resimden 1.
    • Remove the back plate of watch.
  3. Nixon Mission Android Wear Battery Replacement: adım 3, 1 resimden 1.
    • Unclip 5 latches from motherboard using a plastic spudger.
  4. Nixon Mission Android Wear Battery Replacement: adım 4, 1 resimden 1.
    • Remove the 2 3.0mm screws from motherboard using PH00 Phillips head.
  5. Nixon Mission Android Wear Battery Replacement: adım 5, 1 resimden 1.
    • Carefully remove motherboard & internal screen.
  6. Nixon Mission Android Wear Battery Replacement: adım 6, 1 resimden 1.
    • Remove from the motherboard the connector with the four cables.
    • Pull the cables upward and the motherboard downward as shown in the picture.
  7. Nixon Mission Android Wear Battery Replacement: adım 7, 1 resimden 1.
    • Carefully remove the battery from the watch.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Mauricio Ambrosio
191 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S3-G2, Harley Fall 2017 IUPUI, Team S3-G2, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S3G2
3 Üyeler
3 adet Kılavuz yazıldı
18 Yorum
Hi, would you be able to advise where to purchase a replacement battery?
Simon Seow - Yanıt
same here, where to purchase a replacement battery ?
peter.erdogyaraki - Yanıt
Thank you for your tuto.
But now, where I can purchase a new battery?
Thank you
COUTURIER - Yanıt
Hi! Anyone knows where to buy a new battery?
cristian.carvelli - Yanıt
After an extensive search there doesn't seem to be any info out there about battery size…..still
Jerry Jerry J - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 64
Her zaman: 6,299
