Ana içeriğe geç
Nixon Mission Android Wear Motherboard Replacement
Neye ihtiyacın var
  1. Nixon Mission Android Wear Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Unscrew 4 4.5mm Phillips head screws from the back of the device.
  2. Nixon Mission Android Wear Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove back.
  3. Nixon Mission Android Wear Motherboard Replacement: adım 3, 1 resimden 1.
    • Unclip straps holding motherboard to screen using a spudger.
  4. Nixon Mission Android Wear Motherboard Replacement: adım 4, 1 resimden 1.
    • Unscrew 2 3.0mm Phillips head screws holding motherboard in place.
    • The other screw is hidden under the copper band on opposite side.
  5. Nixon Mission Android Wear Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the "core" of the device from case.
  6. Nixon Mission Android Wear Motherboard Replacement: adım 6, 2 resimden 1. Nixon Mission Android Wear Motherboard Replacement: adım 6, 2 resimden 2.
    • Separate motherboard from screen and then clean or replace motherboard.
Sonuç
Spencer Kolzow
170 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S3-G2, Harley Fall 2017 IUPUI, Team S3-G2, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S3G2
3 Üyeler
3 adet Kılavuz yazıldı
2 Yorum
Hello… where can i get the replacement motherboard???
Juan Pablo Balderrama - Yanıt
Is it still waterproof after you open it?
Smarty - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 9
Her zaman: 766
