Giriş
If your Nixon Watch needs a battery replacement, this guide will help if there is any question on how to replace the battery. This guide is specifically only for Nixon Watch. To replace the battery there's no special technical knowledge needed. The only thing that is needed is good lighting and a nice, flat area to keep the tiny screws in place.
Neye ihtiyacın var
On a flat surface, use the PH00 screwdriver to remove the four screws from each corner, and set them in a safe place.
You have successfully completed the battery
replacement on your wristwatch.
If the second hand doesn’t begin its rotation there is
one of two common problems. The first is that the
crown has not been properly engaged after the time
adjustment on steps 11 and 12. The second problem would be caused by a bad battery in which case you would need to repeat the steps over with another new battery.
If the problem persists contact the manufacturer for
further troubleshooting steps.
20 farklı kişi bu kılavuzu tamamladı.
12 Yorum
Works for also for my traser h3. Thank you!
Good guide but one does not need to force out battery with a screwdriver. This is overkill. I would not recommend putting a screwdriver there because the gears are exposed in that area and a slip would damage them. Just a finger nail is needed to move a little spring cover slightly to let battery out. Same goes for putting battery back in. Fingers are all that are needed at that point.
I have a "Newton" model Nixon. All black and the watch hands are floating circles just to clarify. It seems to have a battery cover, almost like a strip, holding it in place. Is there a tutorial for this extra step?
Hey Anthony! were you able to find an answer to your question? I’m also looking to replace my Newton’s battery.
Yash K -
That is for the backlight module. It takes a 2016 battery. The battery seen in this tutorial powers the movement and sits underneath the backlight module.
Thankyou! Worked perfect for my Nixon “Small Player" watch! This was very helpful!
How do i set the time on my the pirouette watch the hanfs just keep turning and wont stop
I have a Nixon yes rocker what size of battery is for the watch it came without one I bought it in another and cant take it back
I meant another country
can you guys help me with my nixon rerun batttery replacement
Is there a tutorial on how to replace the Nixon Re Run Watch? Because I can’t for the life open this watch to replace the battery..
