Ana içeriğe geç
Node Swap
Neye ihtiyacın var
  1. Node Swap, Loosen front tapcon: adım 1, 2 resimden 1. Node Swap, Loosen front tapcon: adım 1, 2 resimden 2.
    • the standard concrete drilled node
    • If your node is clamped or pole mounted skip to step 3
    FixBot'a Sor
    Yorum Ekle
  2. Node Swap, loosen back tapcon and swivel node toward you: adım 2, 1 resimden 1.
    • with the front tapcon removed you should be able to swing the node back toward the concrete surface it's mounted on
    • you'll likely need to loosen the back tapcon and pull up on the cantilever for the node to pivot freely
    FixBot'a Sor
    Yorum Ekle
  3. Node Swap, remove old node: adım 3, 2 resimden 1. Node Swap, remove old node: adım 3, 2 resimden 2.
    • first, note if the pin is weight bearing. if so make sure to support the node while you remove the pin (or lock)
    • pull old node out
    FixBot'a Sor
    Yorum Ekle
  4. Node Swap, replace with new node and measure: adım 4, 1 resimden 1.
    • after sliding a new node in and replacing the pin or lock, measure the distance from the bottom of the ultrasonic depth sensor cone to the top of the cantilever beam. you may find a spare piece of strut to help with this.
    • you should do this before reattaching the front tapcon or clamp
    FixBot'a Sor
    Yorum Ekle
  5. Node Swap: adım 5, 2 resimden 1. Node Swap: adım 5, 2 resimden 2.
    • Using a (weighted) tape measure, measure and record the distance from the bottom of the depth sensor node to the bottom of the river.
    • The bottom of the depth sensor node is defined as the bottom of the sensor cone.
    FixBot'a Sor
    Yorum Ekle
    • if node is drilled into concrete swivel the cantilever back to its full extent and reattach the front tapcon
    • if the node is clamped, reclamp the node at its full extent
    • for a pole-mounted node, you should be able to swap without altering the structure at all
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
Travis Dantzer
266 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 37
Her zaman: 434
