Ana içeriğe geç
Nokero N222-Huron O-Ring Replacement
Neye ihtiyacın var
  1. Nokero N222-Huron O-Ring Replacement, Clear Cover: adım 1, 1 resimden 1.
    • Grasp the clear cover and the white housing and twist the cover counter-clockwise.
    • The lid may hold fast, but it will come off with some firm twisting.
  2. Nokero N222-Huron O-Ring Replacement: adım 2, 1 resimden 1.
    • Lift the lid from the device
    • It may be helpful to use a spudger to pry under the lid if there is difficulty in getting a good grip on the smooth plastic.
  3. Nokero N222-Huron O-Ring Replacement, O-Ring: adım 3, 3 resimden 1. Nokero N222-Huron O-Ring Replacement, O-Ring: adım 3, 3 resimden 2. Nokero N222-Huron O-Ring Replacement, O-Ring: adım 3, 3 resimden 3.
    • Using a plastic spudger, lift the o-ring from the lid
  4. Nokero N222-Huron O-Ring Replacement: adım 4, 1 resimden 1.
    • Gently stretch the new O-ring and place it in position on the clear cover. Make sure it is flush with the flange and not interfering with the locking threads
Sonuç
Vinny Capone
549 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2013 UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2013 üyesi
UMASSD-GULBRANDSEN-F13S2G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 206
