Ana içeriğe geç
Nokero N400 Back Cover Replacement
Neye ihtiyacın var
  1. Nokero N400 Back Cover Replacement, Remove Battery Cover: adım 1, 3 resimden 1. Nokero N400 Back Cover Replacement, Remove Battery Cover: adım 1, 3 resimden 2. Nokero N400 Back Cover Replacement, Remove Battery Cover: adım 1, 3 resimden 3.
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 Back Cover Replacement, Unscrew Back Cover: adım 2, 2 resimden 1. Nokero N400 Back Cover Replacement, Unscrew Back Cover: adım 2, 2 resimden 2.
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 Back Cover Replacement, Pry Open Back Cover: adım 3, 2 resimden 1. Nokero N400 Back Cover Replacement, Pry Open Back Cover: adım 3, 2 resimden 2.
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
Sonuç
Kasey Kolyno
125 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 19-2, Blackwell Winter 2015 USF Tampa, Team 19-2, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S19G2
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 132
