Ana içeriğe geç
Nokero N400 LED Panel Replacement
Neye ihtiyacın var
  1. Nokero N400 LED Panel Replacement, Remove Battery Cover: adım 1, 3 resimden 1. Nokero N400 LED Panel Replacement, Remove Battery Cover: adım 1, 3 resimden 2. Nokero N400 LED Panel Replacement, Remove Battery Cover: adım 1, 3 resimden 3.
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 LED Panel Replacement, Unscrew Back Cover: adım 2, 2 resimden 1. Nokero N400 LED Panel Replacement, Unscrew Back Cover: adım 2, 2 resimden 2.
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 LED Panel Replacement, Pry Open Back Cover: adım 3, 2 resimden 1. Nokero N400 LED Panel Replacement, Pry Open Back Cover: adım 3, 2 resimden 2.
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  4. Nokero N400 LED Panel Replacement, Removing the LED Panel: adım 4, 2 resimden 1. Nokero N400 LED Panel Replacement, Removing the LED Panel: adım 4, 2 resimden 2.
    • With the back cover of the device removed, lightly pull up on the LED assembly to lift it out of its housing.
    • The LED assembly will separate into three components; the light board, outer housing, and plastic lens.
  5. Nokero N400 LED Panel Replacement: adım 5, 1 resimden 1.
    • Set the outer housing and plastic lens aside.
    • Take a pair of pliers and cut the red and black wires connected to the light board.
    • Make sure to cut just below the light board.
    • To install the new light board, you will need to splice or solder the wires to the new light board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kyle Burwell
173 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 19-2, Blackwell Winter 2015 USF Tampa, Team 19-2, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S19G2
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 207
