Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
If your flashlight no longer charges its battery, it might be time to change your solar panel with this guide.
Neye ihtiyacın var
Press down firmly to remove the battery cover and display battery.
Then remove the battery.
Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
Unlatch the clips on the inside and pull device apart.
Pull the panel away from the rest of the assembly and cut the red and black wires coming from the panel
