Ana içeriğe geç
Nokero N400 Suction Cup Replacement
Neye ihtiyacın var
  1. Nokero N400 Suction Cup Replacement, Remove Battery Cover: adım 1, 3 resimden 1. Nokero N400 Suction Cup Replacement, Remove Battery Cover: adım 1, 3 resimden 2. Nokero N400 Suction Cup Replacement, Remove Battery Cover: adım 1, 3 resimden 3.
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 Suction Cup Replacement, Unscrew Back Cover: adım 2, 2 resimden 1. Nokero N400 Suction Cup Replacement, Unscrew Back Cover: adım 2, 2 resimden 2.
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 Suction Cup Replacement, Pry Open Back Cover: adım 3, 2 resimden 1. Nokero N400 Suction Cup Replacement, Pry Open Back Cover: adım 3, 2 resimden 2.
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  4. Nokero N400 Suction Cup Replacement, Begin Removal: adım 4, 2 resimden 1. Nokero N400 Suction Cup Replacement, Begin Removal: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, push the edges of the back end of the suction cup inward.
  5. Nokero N400 Suction Cup Replacement, Remove Suction Cup: adım 5, 2 resimden 1. Nokero N400 Suction Cup Replacement, Remove Suction Cup: adım 5, 2 resimden 2.
    • Flip the cover over and remove the suction cup by pulling at an angle.
    • Be careful not to tear the plastic housing.
    • During reassembly, make sure to press down uniformly on the suction cup for an even fit.
Sonuç
Daniel Bumiller
201 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 19-2, Blackwell Winter 2015 USF Tampa, Team 19-2, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S19G2
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 146
