Ana içeriğe geç
Nokero N400 Switch Replacement
Neye ihtiyacın var
  1. Nokero N400 Switch Replacement, Remove Battery Cover: adım 1, 3 resimden 1. Nokero N400 Switch Replacement, Remove Battery Cover: adım 1, 3 resimden 2. Nokero N400 Switch Replacement, Remove Battery Cover: adım 1, 3 resimden 3.
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 Switch Replacement, Unscrew Back Cover: adım 2, 2 resimden 1. Nokero N400 Switch Replacement, Unscrew Back Cover: adım 2, 2 resimden 2.
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 Switch Replacement, Pry Open Back Cover: adım 3, 2 resimden 1. Nokero N400 Switch Replacement, Pry Open Back Cover: adım 3, 2 resimden 2.
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  4. Nokero N400 Switch Replacement, Remove Switch From Housing: adım 4, 1 resimden 1.
    • Using a spudger carefully pry switch from housing.
  5. Nokero N400 Switch Replacement, Cut Old Switch Free: adım 5, 1 resimden 1.
    • Use wire cutters to cut the two black wires attached to the old switch.
    • You must use a splicer or a soldering gun to reattach the wires of the new switch.
    • If you splice the new switch wires together in the opposite order of the old switch wires, the new switch will still work.
Sonuç
Benjamin franklin
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 19-2, Blackwell Winter 2015 USF Tampa, Team 19-2, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S19G2
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 128
