Ana içeriğe geç
Nokero SunRay Pro Power Panel Capacitor Replacement
Neye ihtiyacın var
  1. Nokero SunRay Pro Power Panel Capacitor Replacement, Front and Back Case: adım 1, 1 resimden 1.
    • Turn over the device so that the back of the device is facing up.
    FixBot'a Sor
    Yorum Ekle
  2. Nokero SunRay Pro Power Panel Capacitor Replacement: adım 2, 3 resimden 1. Nokero SunRay Pro Power Panel Capacitor Replacement: adım 2, 3 resimden 2. Nokero SunRay Pro Power Panel Capacitor Replacement: adım 2, 3 resimden 3.
    • Insert the first plastic opening tool along the side to pry open the case.
    • Sliding the plastic opening tool, while inserted, along the seam may help the removal process.
    • Use a second plastic opening tool to help separate the remaining seams.
    FixBot'a Sor
    Yorum Ekle
  3. Nokero SunRay Pro Power Panel Capacitor Replacement: adım 3, 2 resimden 1. Nokero SunRay Pro Power Panel Capacitor Replacement: adım 3, 2 resimden 2.
    • There is a long strip of double sided adhesive foam tape that prevents the back case from easily being removed.
    • Pull the back case off by applying steady pressure to remove it from the adhesive foam tape.
    FixBot'a Sor
    Yorum Ekle
  4. Nokero SunRay Pro Power Panel Capacitor Replacement: adım 4, 2 resimden 1. Nokero SunRay Pro Power Panel Capacitor Replacement: adım 4, 2 resimden 2.
    • Use the Phillips precision screwdriver to unscrew the two 5.0 mm Phillips screws from the circuit board.
    • Remove the solar panel and circuit board from the front case.
    FixBot'a Sor
    Yorum Ekle
  5. Nokero SunRay Pro Power Panel Capacitor Replacement, Capacitor: adım 5, 1 resimden 1.
    • Use the soldering station to desolder the two contact points around the connections of the capacitor to loosen the metal.
    FixBot'a Sor
    Yorum Ekle
  6. Nokero SunRay Pro Power Panel Capacitor Replacement: adım 6, 1 resimden 1.
    • Pull the capacitor through the circuit board to remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Nicholas Orr
229 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-3, Blackwell Winter 2015 USF Tampa, Team 9-3, Blackwell Winter 2015 üyesi
USFT-BLACKWELL-W15S9G3
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 23
Her zaman: 536
