Ana içeriğe geç
Nokero SunRay Pro Power Panel USB Assembly Replacement
Neye ihtiyacın var
  1. Nokero SunRay Pro Power Panel USB Assembly Replacement, Front and Back Case: adım 1, 1 resimden 1.
    • Turn over the device so that the back of the device is facing up.
    FixBot'a Sor
    Yorum Ekle
  2. Nokero SunRay Pro Power Panel USB Assembly Replacement: adım 2, 3 resimden 1. Nokero SunRay Pro Power Panel USB Assembly Replacement: adım 2, 3 resimden 2. Nokero SunRay Pro Power Panel USB Assembly Replacement: adım 2, 3 resimden 3.
    • Insert the first plastic opening tool along the side to pry open the case.
    • Sliding the plastic opening tool, while inserted, along the seam may help the removal process.
    • Use a second plastic opening tool to help separate the remaining seams.
    FixBot'a Sor
    Yorum Ekle
  3. Nokero SunRay Pro Power Panel USB Assembly Replacement: adım 3, 2 resimden 1. Nokero SunRay Pro Power Panel USB Assembly Replacement: adım 3, 2 resimden 2.
    • There is a long strip of double sided adhesive foam tape that prevents the back case from easily being removed.
    • Pull the back case off by applying steady pressure to remove it from the adhesive foam tape.
    FixBot'a Sor
    Yorum Ekle
  4. Nokero SunRay Pro Power Panel USB Assembly Replacement: adım 4, 2 resimden 1. Nokero SunRay Pro Power Panel USB Assembly Replacement: adım 4, 2 resimden 2.
    • Use the Phillips precision screwdriver to unscrew the two 5.0 mm Phillips screws from the circuit board.
    • Remove the solar panel and circuit board from the front case.
    FixBot'a Sor
    Yorum Ekle
  5. Nokero SunRay Pro Power Panel USB Assembly Replacement, USB Assembly/ Solar Panel: adım 5, 2 resimden 1. Nokero SunRay Pro Power Panel USB Assembly Replacement, USB Assembly/ Solar Panel: adım 5, 2 resimden 2.
    • Solder the two contact points identified by the "S+" and "S-" to disconnect the USB assembly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nicholas Orr
229 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 35
Her zaman: 527
