Ana içeriğe geç
Nokia 1010 Screen Replacement
Neye ihtiyacın var
  1. Nokia 1010 Screen Replacement, Battery: adım 1, 2 resimden 1. Nokia 1010 Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Using your thumbs, press and slide down the back cover of the Nokia 1010.
  2. Nokia 1010 Screen Replacement: adım 2, 3 resimden 1. Nokia 1010 Screen Replacement: adım 2, 3 resimden 2. Nokia 1010 Screen Replacement: adım 2, 3 resimden 3.
    • Insert the prying tool in the notch above the battery.
    • Once the prying tool is inserted, lift up the battery.
  3. Nokia 1010 Screen Replacement, Faceplate: adım 3, 2 resimden 1. Nokia 1010 Screen Replacement, Faceplate: adım 3, 2 resimden 2.
    • Insert the prying tool between the seam of the faceplate and the body.
  4. Nokia 1010 Screen Replacement: adım 4, 3 resimden 1. Nokia 1010 Screen Replacement: adım 4, 3 resimden 2. Nokia 1010 Screen Replacement: adım 4, 3 resimden 3.
    • Starting from the bottom of the phone, begin prying around the base of the phone alternating form left to right.
  5. Nokia 1010 Screen Replacement: adım 5, 3 resimden 1. Nokia 1010 Screen Replacement: adım 5, 3 resimden 2. Nokia 1010 Screen Replacement: adım 5, 3 resimden 3.
    • As the base loosens, slowly increase the separation between the plates and the body of the phone.
  6. Nokia 1010 Screen Replacement, Motherboard: adım 6, 3 resimden 1. Nokia 1010 Screen Replacement, Motherboard: adım 6, 3 resimden 2. Nokia 1010 Screen Replacement, Motherboard: adım 6, 3 resimden 3.
    • Using the spudger, pry back three tabs located on the left edge and three tabs located on the right edge of the body.
  7. Nokia 1010 Screen Replacement: adım 7, 3 resimden 1. Nokia 1010 Screen Replacement: adım 7, 3 resimden 2. Nokia 1010 Screen Replacement: adım 7, 3 resimden 3.
    • Once detached, lift and remove the faceplate from the motherboard.
  8. Nokia 1010 Screen Replacement, Screen: adım 8, 3 resimden 1. Nokia 1010 Screen Replacement, Screen: adım 8, 3 resimden 2. Nokia 1010 Screen Replacement, Screen: adım 8, 3 resimden 3.
    • Locate the four clear tabs that connect the screen to the motherboard.
  9. Nokia 1010 Screen Replacement: adım 9, 3 resimden 1. Nokia 1010 Screen Replacement: adım 9, 3 resimden 2. Nokia 1010 Screen Replacement: adım 9, 3 resimden 3.
    • Insert the prying tool between the tabs and the motherboard. Loosen and separate slowly.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
يبقه على الشعار مال النوكيه بس
حيدر حمود - Yanıt
You didn't even removed the screen you just removed the glass.
Macro Man - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 38
Her zaman: 2,454
