Ana içeriğe geç
Nokia 1010 Speaker Replacement
Neye ihtiyacın var
  1. Nokia 1010 Speaker Replacement, Battery: adım 1, 2 resimden 1. Nokia 1010 Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Using your thumbs, press and slide down the back cover of the Nokia 1010.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia 1010 Speaker Replacement: adım 2, 3 resimden 1. Nokia 1010 Speaker Replacement: adım 2, 3 resimden 2. Nokia 1010 Speaker Replacement: adım 2, 3 resimden 3.
    • Insert the prying tool in the notch above the battery.
    • Once the prying tool is inserted, lift up the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia 1010 Speaker Replacement, Faceplate: adım 3, 2 resimden 1. Nokia 1010 Speaker Replacement, Faceplate: adım 3, 2 resimden 2.
    • Insert the prying tool between the seam of the faceplate and the body.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia 1010 Speaker Replacement: adım 4, 3 resimden 1. Nokia 1010 Speaker Replacement: adım 4, 3 resimden 2. Nokia 1010 Speaker Replacement: adım 4, 3 resimden 3.
    • Starting from the bottom of the phone, begin prying around the base of the phone alternating form left to right.
    FixBot'a Sor
    Yorum Ekle
  5. Nokia 1010 Speaker Replacement: adım 5, 3 resimden 1. Nokia 1010 Speaker Replacement: adım 5, 3 resimden 2. Nokia 1010 Speaker Replacement: adım 5, 3 resimden 3.
    • As the base loosens, slowly increase the separation between the plates and the body of the phone.
    FixBot'a Sor
    Yorum Ekle
  6. Nokia 1010 Speaker Replacement, Motherboard: adım 6, 3 resimden 1. Nokia 1010 Speaker Replacement, Motherboard: adım 6, 3 resimden 2. Nokia 1010 Speaker Replacement, Motherboard: adım 6, 3 resimden 3.
    • Using the spudger, pry back three tabs located on the left edge and three tabs located on the right edge of the body.
    FixBot'a Sor
    Yorum Ekle
  7. Nokia 1010 Speaker Replacement: adım 7, 3 resimden 1. Nokia 1010 Speaker Replacement: adım 7, 3 resimden 2. Nokia 1010 Speaker Replacement: adım 7, 3 resimden 3.
    • Once detached, lift and remove the faceplate from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  8. Nokia 1010 Speaker Replacement, Speaker: adım 8, 3 resimden 1. Nokia 1010 Speaker Replacement, Speaker: adım 8, 3 resimden 2. Nokia 1010 Speaker Replacement, Speaker: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Insert tweezers into the small crevices of the backside of the speaker, and lift upwards.
    FixBot'a Sor
    Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 46
Her zaman: 1,958
