Ana içeriğe geç
Nokia 1100b RH-36 Motherboard and Keyboard Replacement
Neye ihtiyacın var
  1. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery Cover: adım 1, 2 resimden 1. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery Cover: adım 1, 2 resimden 2.
    • Flip the phone over so that the screen faces down.
    • Press the gray button on the battery cover and slide it down off the back of the phone.
  2. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery: adım 2, 1 resimden 1.
    • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
    • Gently pry the battery out of the phone.
  3. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Inner Casing: adım 3, 2 resimden 1. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Inner Casing: adım 3, 2 resimden 2.
    • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
    • Remove the metal frame holding the screen and speaker.
  4. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Motherboard and Keyboard: adım 4, 2 resimden 1. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Motherboard and Keyboard: adım 4, 2 resimden 2.
    • Gently lift motherboard unit out of the case.
    • The motherboard and keyboard are one unit and are replaced together.
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
James Szelenyi
283 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-43, Amido Spring 2013 Cal Poly, Team 10-43, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S10G43
4 Üyeler
14 adet Kılavuz yazıldı
1Rehber Yorum
you nokia 1100 mother board please soon date…?
ajay gupta - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 57
Her zaman: 4,599
