Ana içeriğe geç
Nokia 1100b RH-36 Screen Replacement
Neye ihtiyacın var
    1. Nokia 1100b RH-36 Screen Replacement, Battery Cover: adım 1, 2 resimden 1. Nokia 1100b RH-36 Screen Replacement, Battery Cover: adım 1, 2 resimden 2.
      • Flip the phone over so that the screen faces down.
      • Press the gray button on the battery cover and slide it down off the back of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. Nokia 1100b RH-36 Screen Replacement, Battery: adım 2, 1 resimden 1.
      • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
      • Gently pry the battery out of the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Nokia 1100b RH-36 Screen Replacement, Front Cover: adım 3, 2 resimden 1. Nokia 1100b RH-36 Screen Replacement, Front Cover: adım 3, 2 resimden 2.
      • Firmly grip the back of the casing.
      • Separate the front and back casings either by pulling them apart from the middle or gently prying the front off with your fingers from the bottom.
      • Be sure not to bend the casing too much when prying from the bottom. Failure to do so may cause it to crack.
      FixBot'a Sor
      Yorum Ekle
    1. Nokia 1100b RH-36 Screen Replacement, Inner Casing: adım 4, 2 resimden 1. Nokia 1100b RH-36 Screen Replacement, Inner Casing: adım 4, 2 resimden 2.
      • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
      • Remove the metal frame holding the screen and speaker.
      FixBot'a Sor
      Yorum Ekle
    1. Nokia 1100b RH-36 Screen Replacement, Screen: adım 5, 2 resimden 1. Nokia 1100b RH-36 Screen Replacement, Screen: adım 5, 2 resimden 2.
      • Flip over the metal frame you just removed.
      • Using the flat end of the spudger, pry apart the inner clear plastic frame with screen attached from the metal frame.
      • Remove the screen bearing plastic frame.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
JSwan
811 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-43, Amido Spring 2013 Cal Poly, Team 10-43, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S10G43
4 Üyeler
84 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 33
Her zaman: 2,483
