Ana içeriğe geç
Nokia 1100b RH-36 Speaker Replacement
Neye ihtiyacın var
  1. Nokia 1100b RH-36 Speaker Replacement, Battery Cover: adım 1, 2 resimden 1. Nokia 1100b RH-36 Speaker Replacement, Battery Cover: adım 1, 2 resimden 2.
    • Flip the phone over so that the screen faces down.
    • Press the gray button on the battery cover and slide it down off the back of the phone.
  2. Nokia 1100b RH-36 Speaker Replacement, Battery: adım 2, 1 resimden 1.
    • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
    • Gently pry the battery out of the phone.
  3. Nokia 1100b RH-36 Speaker Replacement, Inner Casing: adım 3, 2 resimden 1. Nokia 1100b RH-36 Speaker Replacement, Inner Casing: adım 3, 2 resimden 2.
    • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
    • Remove the metal frame holding the screen and speaker.
  4. Nokia 1100b RH-36 Speaker Replacement, Screen: adım 4, 2 resimden 1. Nokia 1100b RH-36 Speaker Replacement, Screen: adım 4, 2 resimden 2.
    • Flip over the metal frame you just removed.
    • Using the flat end of the spudger, pry apart the inner clear plastic frame with screen attached from the metal frame.
    • Remove the screen bearing plastic frame.
  5. Nokia 1100b RH-36 Speaker Replacement, Speaker: adım 5, 2 resimden 1. Nokia 1100b RH-36 Speaker Replacement, Speaker: adım 5, 2 resimden 2.
    • Gently remove the speaker from the top of the metal frame.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
JSwan
751 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-43, Amido Spring 2013 Cal Poly, Team 10-43, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S10G43
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 1,938
