Ana içeriğe geç
Nokia 2115i Faceplate Replacement
Neye ihtiyacın var
  1. Nokia 2115i Faceplate Replacement, Nokia 2115i Battery: adım 1, 3 resimden 1. Nokia 2115i Faceplate Replacement, Nokia 2115i Battery: adım 1, 3 resimden 2. Nokia 2115i Faceplate Replacement, Nokia 2115i Battery: adım 1, 3 resimden 3.
    • To prevent shock, press down on the power button located on the top of the phone until the phone shuts off.
    • Press down on the small gray button located on the back of the phone.
    • Slide the back plate down and off.
  2. Nokia 2115i Faceplate Replacement: adım 2, 2 resimden 1. Nokia 2115i Faceplate Replacement: adım 2, 2 resimden 2.
    • To remove the battery, begin by holding the phone sideways.
    • Then, insert your thumb in the groove below the battery and push the battery up and out.
  3. Nokia 2115i Faceplate Replacement, Faceplate: adım 3, 3 resimden 1. Nokia 2115i Faceplate Replacement, Faceplate: adım 3, 3 resimden 2. Nokia 2115i Faceplate Replacement, Faceplate: adım 3, 3 resimden 3.
    • Locate the spudger. A photo of the correct spudger is provided to the left.
    • Turn the front of the phone to face you. Find the two small square holes on the bottom left and right sides of the faceplate.
    • Insert the spudger into each square hole and push up to detach the face plate.
Sonuç
Shane
80 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-38, Forte Fall 2010 Cal Poly, Team 14-38, Forte Fall 2010 üyesi
CPSU-FORTE-F10S14G38
5 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 25
Son 30 gün: 78
Her zaman: 1,892
