Ana içeriğe geç
Nokia 2115i Motherboard Replacement
Neye ihtiyacın var
  1. Nokia 2115i Motherboard Replacement, Nokia 2115i Battery: adım 1, 3 resimden 1. Nokia 2115i Motherboard Replacement, Nokia 2115i Battery: adım 1, 3 resimden 2. Nokia 2115i Motherboard Replacement, Nokia 2115i Battery: adım 1, 3 resimden 3.
    • To prevent shock, press down on the power button located on the top of the phone until the phone shuts off.
    • Press down on the small gray button located on the back of the phone.
    • Slide the back plate down and off.
  2. Nokia 2115i Motherboard Replacement: adım 2, 2 resimden 1. Nokia 2115i Motherboard Replacement: adım 2, 2 resimden 2.
    • To remove the battery, begin by holding the phone sideways.
    • Then, insert your thumb in the groove below the battery and push the battery up and out.
  3. Nokia 2115i Motherboard Replacement, Faceplate: adım 3, 3 resimden 1. Nokia 2115i Motherboard Replacement, Faceplate: adım 3, 3 resimden 2. Nokia 2115i Motherboard Replacement, Faceplate: adım 3, 3 resimden 3.
    • Locate the spudger. A photo of the correct spudger is provided to the left.
    • Turn the front of the phone to face you. Find the two small square holes on the bottom left and right sides of the faceplate.
    • Insert the spudger into each square hole and push up to detach the face plate.
  4. Nokia 2115i Motherboard Replacement, Removing the Keypad: adım 4, 2 resimden 1. Nokia 2115i Motherboard Replacement, Removing the Keypad: adım 4, 2 resimden 2.
    • Note: The keypad will be loose and may fall off during this step.
    • Pull the face plate up and off of the phone.
    • To remove the keypad, simply lift it off the phone.
  5. Nokia 2115i Motherboard Replacement, Removing the Motherboard: adım 5, 2 resimden 1. Nokia 2115i Motherboard Replacement, Removing the Motherboard: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Locate the 6 screws on the metallic sheet that previously held the keypad. (This sheet, shown in the pictures, is the top side of the motherboard).
    • Note: 2 of the screws are on the bottom corners, 2 are on the right and left edges of the phone below the screen, and 2 are on the very top corners of the phone, above the screen.
    • Warning: The middle two screws are attached to the base of the phone with two black plastic rings. Use tweezers to remove the screws carefully to avoid breaking the plastic rings
    • Use a size T6 Torx screwdriver to remove each of these 6 screws.
  6. Nokia 2115i Motherboard Replacement: adım 6, 3 resimden 1. Nokia 2115i Motherboard Replacement: adım 6, 3 resimden 2. Nokia 2115i Motherboard Replacement: adım 6, 3 resimden 3.
    • To remove the motherboard, lift it up and off the phone.
    • Note: The screen will still be attached to the motherboard.
Sonuç
Shane
80 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-38, Forte Fall 2010 Cal Poly, Team 14-38, Forte Fall 2010 üyesi
CPSU-FORTE-F10S14G38
5 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 62
Her zaman: 3,283
