Ana içeriğe geç
Nokia 2115i Screen Replacement
Neye ihtiyacın var
  1. Nokia 2115i Screen Replacement, Nokia 2115i Battery: adım 1, 3 resimden 1. Nokia 2115i Screen Replacement, Nokia 2115i Battery: adım 1, 3 resimden 2. Nokia 2115i Screen Replacement, Nokia 2115i Battery: adım 1, 3 resimden 3.
    • To prevent shock, press down on the power button located on the top of the phone until the phone shuts off.
    • Press down on the small gray button located on the back of the phone.
    • Slide the back plate down and off.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia 2115i Screen Replacement: adım 2, 2 resimden 1. Nokia 2115i Screen Replacement: adım 2, 2 resimden 2.
    • To remove the battery, begin by holding the phone sideways.
    • Then, insert your thumb in the groove below the battery and push the battery up and out.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia 2115i Screen Replacement, Faceplate: adım 3, 3 resimden 1. Nokia 2115i Screen Replacement, Faceplate: adım 3, 3 resimden 2. Nokia 2115i Screen Replacement, Faceplate: adım 3, 3 resimden 3.
    • Locate the spudger. A photo of the correct spudger is provided to the left.
    • Turn the front of the phone to face you. Find the two small square holes on the bottom left and right sides of the faceplate.
    • Insert the spudger into each square hole and push up to detach the face plate.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia 2115i Screen Replacement, Removing the Keypad: adım 4, 2 resimden 1. Nokia 2115i Screen Replacement, Removing the Keypad: adım 4, 2 resimden 2.
    • Note: The keypad will be loose and may fall off during this step.
    • Pull the face plate up and off of the phone.
    • To remove the keypad, simply lift it off the phone.
    FixBot'a Sor
    Yorum Ekle
  5. Nokia 2115i Screen Replacement, Removing the Motherboard: adım 5, 2 resimden 1. Nokia 2115i Screen Replacement, Removing the Motherboard: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Locate the 6 screws on the metallic sheet that previously held the keypad. (This sheet, shown in the pictures, is the top side of the motherboard).
    • Note: 2 of the screws are on the bottom corners, 2 are on the right and left edges of the phone below the screen, and 2 are on the very top corners of the phone, above the screen.
    • Warning: The middle two screws are attached to the base of the phone with two black plastic rings. Use tweezers to remove the screws carefully to avoid breaking the plastic rings
    • Use a size T6 Torx screwdriver to remove each of these 6 screws.
    FixBot'a Sor
    Yorum Ekle
  6. Nokia 2115i Screen Replacement: adım 6, 3 resimden 1. Nokia 2115i Screen Replacement: adım 6, 3 resimden 2. Nokia 2115i Screen Replacement: adım 6, 3 resimden 3.
    • To remove the motherboard, lift it up and off the phone.
    • Note: The screen will still be attached to the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. Nokia 2115i Screen Replacement, Replacing the Screen: adım 7, 2 resimden 1. Nokia 2115i Screen Replacement, Replacing the Screen: adım 7, 2 resimden 2.
    • Turn the screen/motherboard so that the screen side is facing down as shown in the first picture of this step.
    • With your fingers, push the black tabs on the upper left and upper right sides of the motherboard outward. You can see this in the second picture of this step.
    FixBot'a Sor
    Yorum Ekle
  8. Nokia 2115i Screen Replacement: adım 8, 2 resimden 1. Nokia 2115i Screen Replacement: adım 8, 2 resimden 2.
    • Turn the motherboard so that the screen faces upward, as seen in the photos.
    • Holding the sides of the screen, pull the screen up and off of the motherboard.
    • Note: When you remove the screen from the motherboard, resistance is normal.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Shane
80 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-38, Forte Fall 2010 Cal Poly, Team 14-38, Forte Fall 2010 üyesi
CPSU-FORTE-F10S14G38
5 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 59
Her zaman: 2,096
