Ana içeriğe geç
Nokia 2128i Internal Clock Battery Replacement
Neye ihtiyacın var
  1. Nokia 2128i Internal Clock Battery Replacement, Battery: adım 1, 3 resimden 1. Nokia 2128i Internal Clock Battery Replacement, Battery: adım 1, 3 resimden 2. Nokia 2128i Internal Clock Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Be sure cell phone is off before you begin to disassemble the phone.
    • Press the button on the bottom of the back of the cell phone.
    • Slide rear panel down and remove it.
  2. Nokia 2128i Internal Clock Battery Replacement: adım 2, 3 resimden 1. Nokia 2128i Internal Clock Battery Replacement: adım 2, 3 resimden 2. Nokia 2128i Internal Clock Battery Replacement: adım 2, 3 resimden 3.
    • Using your fingernail, pry the back of the battery upwards and pull out.
  3. Nokia 2128i Internal Clock Battery Replacement, Faceplate: adım 3, 3 resimden 1. Nokia 2128i Internal Clock Battery Replacement, Faceplate: adım 3, 3 resimden 2. Nokia 2128i Internal Clock Battery Replacement, Faceplate: adım 3, 3 resimden 3.
    • Insert the plastic opening tool under the faceplate.
    • Separate the faceplate from main body by twisting the prying tool with some force.
    • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
  4. Nokia 2128i Internal Clock Battery Replacement, Keypad: adım 4, 3 resimden 1. Nokia 2128i Internal Clock Battery Replacement, Keypad: adım 4, 3 resimden 2. Nokia 2128i Internal Clock Battery Replacement, Keypad: adım 4, 3 resimden 3.
    • With the faceplate removed, simply peel off rubber key pad and remove.
  5. Nokia 2128i Internal Clock Battery Replacement, Motherboard Assembly: adım 5, 3 resimden 1. Nokia 2128i Internal Clock Battery Replacement, Motherboard Assembly: adım 5, 3 resimden 2. Nokia 2128i Internal Clock Battery Replacement, Motherboard Assembly: adım 5, 3 resimden 3.
    • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
  6. Nokia 2128i Internal Clock Battery Replacement: adım 6, 3 resimden 1. Nokia 2128i Internal Clock Battery Replacement: adım 6, 3 resimden 2. Nokia 2128i Internal Clock Battery Replacement: adım 6, 3 resimden 3.
    • After removing screws, lift the motherboard assembly straight off the cell phone body.
  7. Nokia 2128i Internal Clock Battery Replacement, Internal Clock Battery: adım 7, 2 resimden 1. Nokia 2128i Internal Clock Battery Replacement, Internal Clock Battery: adım 7, 2 resimden 2.
    • With the logic board completely removed, gently pry out the internal clock battery from its housing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Curtis Lutje
28 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-8, Maness Fall 2010 Cal Poly, Team 20-8, Maness Fall 2010 üyesi
CPSU-MANESS-F10S20G8
4 Üyeler
24 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 3,376
