Ana içeriğe geç
Nokia 2128i Keypad Replacement
Neye ihtiyacın var
  1. Nokia 2128i Keypad Replacement, Battery: adım 1, 3 resimden 1. Nokia 2128i Keypad Replacement, Battery: adım 1, 3 resimden 2. Nokia 2128i Keypad Replacement, Battery: adım 1, 3 resimden 3.
    • Be sure cell phone is off before you begin to disassemble the phone.
    • Press the button on the bottom of the back of the cell phone.
    • Slide rear panel down and remove it.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia 2128i Keypad Replacement: adım 2, 3 resimden 1. Nokia 2128i Keypad Replacement: adım 2, 3 resimden 2. Nokia 2128i Keypad Replacement: adım 2, 3 resimden 3.
    • Using your fingernail, pry the back of the battery upwards and pull out.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia 2128i Keypad Replacement, Faceplate: adım 3, 3 resimden 1. Nokia 2128i Keypad Replacement, Faceplate: adım 3, 3 resimden 2. Nokia 2128i Keypad Replacement, Faceplate: adım 3, 3 resimden 3.
    • Insert the plastic opening tool under the faceplate.
    • Separate the faceplate from main body by twisting the prying tool with some force.
    • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia 2128i Keypad Replacement, Keypad: adım 4, 3 resimden 1. Nokia 2128i Keypad Replacement, Keypad: adım 4, 3 resimden 2. Nokia 2128i Keypad Replacement, Keypad: adım 4, 3 resimden 3.
    • With the faceplate removed, simply peel off rubber key pad and remove.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Chad
28 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-8, Maness Fall 2010 Cal Poly, Team 20-8, Maness Fall 2010 üyesi
CPSU-MANESS-F10S20G8
4 Üyeler
36 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 32
Her zaman: 1,487
