Parçalar
Hiçbir parçaya gerek yok.
Be sure cell phone is off before you begin to disassemble the phone. Press the button on the bottom of the back of the cell phone. Slide rear panel down and remove  it.
  • Be sure cell phone is off before you begin to disassemble the phone.
  • Press the button on the bottom of the back of the cell phone.
  • Slide rear panel down and remove it.
Yorum Ekle
Using your fingernail, pry the back of the battery upwards and pull out. Using your fingernail, pry the back of the battery upwards and pull out. Using your fingernail, pry the back of the battery upwards and pull out.
  • Using your fingernail, pry the back of the battery upwards and pull out.
Yorum Ekle
Insert the plastic opening tool under the faceplate. Separate the faceplate from main body by twisting the prying tool with some force. The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
  • Insert the plastic opening tool under the faceplate.
  • Separate the faceplate from main body by twisting the prying tool with some force.
  • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
Yorum Ekle
With the faceplate removed, simply peel off rubber key pad and remove. With the faceplate removed, simply peel off rubber key pad and remove. With the faceplate removed, simply peel off rubber key pad and remove.
  • With the faceplate removed, simply peel off rubber key pad and remove.
Yorum Ekle
Locate and remove the six screws on the front of the phone using a T6 Torx. All 6 screws are 6.9mm long. All 6 screws are 6.9mm long.
  • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
Yorum Ekle
After removing screws, lift the motherboard assembly straight off the cell phone body. After removing screws, lift the motherboard assembly straight off the cell phone body. After removing screws, lift the motherboard assembly straight off the cell phone body.
  • After removing screws, lift the motherboard assembly straight off the cell phone body.
Yorum Ekle
Locate the two plastic LCD unit hooks. Pry hooks outward. Pry hooks outward.
  • Locate the two plastic LCD unit hooks.
  • Pry hooks outward.
Yorum Ekle
Gently pull LCD unit away from the logic board. Be careful not to damage the connection on the top, right hand side of the logic board. Be careful not to damage the connection on the top, right hand side of the logic board.
  • Gently pull LCD unit away from the logic board.
    • Be careful not to damage the connection on the top, right hand side of the logic board.
Yorum Ekle
With the LCD unit removed, gently press out the speaker with a non-metallic pointed object. With the LCD unit removed, gently press out the speaker with a non-metallic pointed object. With the LCD unit removed, gently press out the speaker with a non-metallic pointed object.
  • With the LCD unit removed, gently press out the speaker with a non-metallic pointed object.
Yorum Ekle
Sonuç
Andres Echeverria
4 İtibar
6 adet Kılavuz yazıldı
Takım
Cal Poly, Team 20-8, Maness Fall 2010 Cal Poly, Team 20-8, Maness Fall 2010 üyesi
CPSU-MANESS-F10S20G8
4 Üyeler
28 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 3
Her zaman: 189
