Neye ihtiyacın var
Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
Insert the plastic opening tool into the crack between the front and back panels.
Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
Use the Torx screwdriver with the T6 attachmet to remove the 6 .4 mm screws around the outside of the circuit board.
5 farklı kişi bu kılavuzu tamamladı.
