Ana içeriğe geç
Nokia 2610 Keypad Replacement
Neye ihtiyacın var
  1. Nokia 2610 Keypad Replacement, Battery and Sim Card: adım 1, 3 resimden 1. Nokia 2610 Keypad Replacement, Battery and Sim Card: adım 1, 3 resimden 2. Nokia 2610 Keypad Replacement, Battery and Sim Card: adım 1, 3 resimden 3.
    • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
  2. Nokia 2610 Keypad Replacement: adım 2, 3 resimden 1. Nokia 2610 Keypad Replacement: adım 2, 3 resimden 2. Nokia 2610 Keypad Replacement: adım 2, 3 resimden 3.
    • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
  3. Nokia 2610 Keypad Replacement: adım 3, 3 resimden 1. Nokia 2610 Keypad Replacement: adım 3, 3 resimden 2. Nokia 2610 Keypad Replacement: adım 3, 3 resimden 3.
    • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
    • After removal, lower the metal sim card holder into its original position.
  4. Nokia 2610 Keypad Replacement, Front Pannel: adım 4, 2 resimden 1. Nokia 2610 Keypad Replacement, Front Pannel: adım 4, 2 resimden 2.
    • Insert the plastic opening tool into the crack between the front and back panels.
    • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
  5. Nokia 2610 Keypad Replacement: adım 5, 2 resimden 1. Nokia 2610 Keypad Replacement: adım 5, 2 resimden 2.
    • Lift the bottom of the front cover away from the phone.
    • Continue lifting until the top of the front cover is fully removed from the phone.
    • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
  6. Nokia 2610 Keypad Replacement, Keypad: adım 6, 2 resimden 1. Nokia 2610 Keypad Replacement, Keypad: adım 6, 2 resimden 2.
    • Push on the keypad from the exterior of the phone's front cover to separate the keypad from the phone.
Sonuç
Jeff Carter
94 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 7-52, Amido Fall 2010 Cal Poly, Team 7-52, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S7G52
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 2,153
