Ana içeriğe geç
Nokia 2610 Screen Replacement
Neye ihtiyacın var
  1. Nokia 2610 Screen Replacement, Battery and Sim Card: adım 1, 3 resimden 1. Nokia 2610 Screen Replacement, Battery and Sim Card: adım 1, 3 resimden 2. Nokia 2610 Screen Replacement, Battery and Sim Card: adım 1, 3 resimden 3.
    • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia 2610 Screen Replacement: adım 2, 3 resimden 1. Nokia 2610 Screen Replacement: adım 2, 3 resimden 2. Nokia 2610 Screen Replacement: adım 2, 3 resimden 3.
    • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia 2610 Screen Replacement: adım 3, 3 resimden 1. Nokia 2610 Screen Replacement: adım 3, 3 resimden 2. Nokia 2610 Screen Replacement: adım 3, 3 resimden 3.
    • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
    • After removal, lower the metal sim card holder into its original position.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia 2610 Screen Replacement, Front Pannel: adım 4, 2 resimden 1. Nokia 2610 Screen Replacement, Front Pannel: adım 4, 2 resimden 2.
    • Insert the plastic opening tool into the crack between the front and back panels.
    • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
    FixBot'a Sor
    Yorum Ekle
  5. Nokia 2610 Screen Replacement: adım 5, 2 resimden 1. Nokia 2610 Screen Replacement: adım 5, 2 resimden 2.
    • Lift the bottom of the front cover away from the phone.
    • Continue lifting until the top of the front cover is fully removed from the phone.
    • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
    FixBot'a Sor
    Yorum Ekle
  6. Nokia 2610 Screen Replacement, Screen: adım 6, 1 resimden 1.
    • Remove the 4 screws surrounding the screen using the precision T6 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Nokia 2610 Screen Replacement: adım 7, 1 resimden 1.
    • Lift the screen away from the phone and circuit board.
    • Warning: The screen is attached to the circuit board by a connector on the circuit board, so lift the screen straight up to avoid damage to the connector.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Andrew Wood
336 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-52, Amido Fall 2010 Cal Poly, Team 7-52, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S7G52
4 Üyeler
24 adet Kılavuz yazıldı
1Rehber Yorum
My Nokia 2610 dates from 2005 (or2006) and its screen was very scratched.
I bought a complete front cover replacement from vmobile.pl who were very efficient.
Andrew Wood’s instructions are crystal clear. The phone is as new now.
Many thanks. Andrew Boxall
Andrew - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 37
Her zaman: 3,681
