Ana içeriğe geç
Nokia 2610 Speaker Replacement
Neye ihtiyacın var
    1. Nokia 2610 Speaker Replacement, Battery and Sim Card: adım 1, 3 resimden 1. Nokia 2610 Speaker Replacement, Battery and Sim Card: adım 1, 3 resimden 2. Nokia 2610 Speaker Replacement, Battery and Sim Card: adım 1, 3 resimden 3.
      • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
      FixBot'a Sor
      Yorum Ekle
    2. Nokia 2610 Speaker Replacement: adım 2, 3 resimden 1. Nokia 2610 Speaker Replacement: adım 2, 3 resimden 2. Nokia 2610 Speaker Replacement: adım 2, 3 resimden 3.
      • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
      FixBot'a Sor
      Yorum Ekle
    3. Nokia 2610 Speaker Replacement: adım 3, 3 resimden 1. Nokia 2610 Speaker Replacement: adım 3, 3 resimden 2. Nokia 2610 Speaker Replacement: adım 3, 3 resimden 3.
      • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
      • After removal, lower the metal sim card holder into its original position.
      FixBot'a Sor
      Yorum Ekle
    1. Nokia 2610 Speaker Replacement, Front Pannel: adım 4, 2 resimden 1. Nokia 2610 Speaker Replacement, Front Pannel: adım 4, 2 resimden 2.
      • Insert the plastic opening tool into the crack between the front and back panels.
      • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. Nokia 2610 Speaker Replacement: adım 5, 2 resimden 1. Nokia 2610 Speaker Replacement: adım 5, 2 resimden 2.
      • Lift the bottom of the front cover away from the phone.
      • Continue lifting until the top of the front cover is fully removed from the phone.
      • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
      FixBot'a Sor
      Yorum Ekle
    1. Nokia 2610 Speaker Replacement, Circuit Board: adım 6, 1 resimden 1.
      • Use the Torx screwdriver with the T6 attachmet to remove the 6 .4 mm screws around the outside of the circuit board.
      • Note: Removing the 4 T6 screws around the screen will loosen it, so don't worry if the screen also separates from the circuit board.
      FixBot'a Sor
      Yorum Ekle
    2. Nokia 2610 Speaker Replacement: adım 7, 3 resimden 1. Nokia 2610 Speaker Replacement: adım 7, 3 resimden 2. Nokia 2610 Speaker Replacement: adım 7, 3 resimden 3.
      • Lift the circuit board out of the back cover.
      FixBot'a Sor
      Yorum Ekle
    1. Nokia 2610 Speaker Replacement, Speaker: adım 8, 3 resimden 1. Nokia 2610 Speaker Replacement, Speaker: adım 8, 3 resimden 2. Nokia 2610 Speaker Replacement, Speaker: adım 8, 3 resimden 3.
      • Using the plastic opening tool, gently pry the speaker out of its slot in the back cover of the phone.
      • Note: The easiest way to remove the speaker is to insert the plastic opening tool in the upper right corner of the speaker.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Taylor Hinsdale
93 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-52, Amido Fall 2010 Cal Poly, Team 7-52, Amido Fall 2010 üyesi
CPSU-AMIDO-F10S7G52
4 Üyeler
42 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 3,107
