Ana içeriğe geç
Nokia 3100b Screen Replacement
Neye ihtiyacın var
  1. Nokia 3100b Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure your phone is turned off.
  2. Nokia 3100b Screen Replacement: adım 2, 1 resimden 1.
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Nokia 3100b Screen Replacement, SIM Card: adım 3, 1 resimden 1.
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
  4. Nokia 3100b Screen Replacement: adım 4, 1 resimden 1.
    • Retrieve your SIM card.
  5. Nokia 3100b Screen Replacement, Screen: adım 5, 1 resimden 1.
    • Separate the front cover from the main body of the phone.
  6. Nokia 3100b Screen Replacement: adım 6, 1 resimden 1.
    • Remove the six screws along the edges of the phone.
  7. Nokia 3100b Screen Replacement: adım 7, 1 resimden 1.
    • Pull the screen assembly from the base of the phone.
  8. Nokia 3100b Screen Replacement: adım 8, 1 resimden 1.
    • Carefully lift the keypad portion of the screen assembly from the circuit board.
  9. Nokia 3100b Screen Replacement: adım 9, 1 resimden 1.
    • Separate the screen from the circuit board.
    • Reconnect the ports during reassembly or the screen will not function properly.
    • Remember to reconnect the screen to the circuit board when reassembling!
  10. Nokia 3100b Screen Replacement: adım 10, 1 resimden 1.
    • Gently push down on the screen to pop it off of the assembly.
  11. Nokia 3100b Screen Replacement: adım 11, 1 resimden 1.
    • When the screen falls out the assembly, two white tabs will fall out with it.
    • When reinstalling the screen, insert the tabs with the slanted side pointing upwards so they slide into the assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sterling Fuentes
139 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 29-64, Johann Spring 2010 Cal Poly, Team 29-64, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S29G64
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 22
Son 30 gün: 94
Her zaman: 2,142
