Ana içeriğe geç
Nokia 3120 Liquid Crystal Display (LCD) Replacement
Neye ihtiyacın var
    1. Nokia 3120 Liquid Crystal Display (LCD) Replacement, Battery Installation: adım 1, 3 resimden 1. Nokia 3120 Liquid Crystal Display (LCD) Replacement, Battery Installation: adım 1, 3 resimden 2. Nokia 3120 Liquid Crystal Display (LCD) Replacement, Battery Installation: adım 1, 3 resimden 3.
      • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. Nokia 3120 Liquid Crystal Display (LCD) Replacement: adım 2, 1 resimden 1.
      • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
      FixBot'a Sor
      Yorum Ekle
    1. Nokia 3120 Liquid Crystal Display (LCD) Replacement, Face Plate: adım 3, 3 resimden 1. Nokia 3120 Liquid Crystal Display (LCD) Replacement, Face Plate: adım 3, 3 resimden 2. Nokia 3120 Liquid Crystal Display (LCD) Replacement, Face Plate: adım 3, 3 resimden 3.
      • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
      FixBot'a Sor
      Yorum Ekle
    1. Nokia 3120 Liquid Crystal Display (LCD) Replacement, Liquid Crystal Display (LCD): adım 4, 1 resimden 1.
      • Once the cover plate has been removed, the keypad should easily pop out.
      FixBot'a Sor
      Yorum Ekle
    2. Nokia 3120 Liquid Crystal Display (LCD) Replacement: adım 5, 2 resimden 1. Nokia 3120 Liquid Crystal Display (LCD) Replacement: adım 5, 2 resimden 2.
      • Using a screwdriver, remove the 6, 7 mm Torx-head screws on the front of the phone.
      FixBot'a Sor
      Yorum Ekle
    3. Nokia 3120 Liquid Crystal Display (LCD) Replacement: adım 6, 1 resimden 1.
      • Once the screws have been removed, the front plate of the phone should be removed, exposing the inside electronic components of the phone.
      FixBot'a Sor
      Yorum Ekle
    4. Nokia 3120 Liquid Crystal Display (LCD) Replacement: adım 7, 1 resimden 1.
      • Take out the cell phone electronic board
      FixBot'a Sor
      Yorum Ekle
    5. Nokia 3120 Liquid Crystal Display (LCD) Replacement: adım 8, 1 resimden 1.
      • The LCD screen can now be removed from the body of the phone.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Pierre Tong
92 İtibar
4 adet Kılavuz yazıldı
Ekip
Clemson, Team 13-2, Benson Spring 2013 Clemson, Team 13-2, Benson Spring 2013 üyesi
CLEM-BENSON-S13S13G2
3 Üyeler
63 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 35
Her zaman: 1,877
