Ana içeriğe geç
Nokia 3120 Speaker Replacement
Neye ihtiyacın var
  1. Nokia 3120 Speaker Replacement, Battery Installation: adım 1, 3 resimden 1. Nokia 3120 Speaker Replacement, Battery Installation: adım 1, 3 resimden 2. Nokia 3120 Speaker Replacement, Battery Installation: adım 1, 3 resimden 3.
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
  2. Nokia 3120 Speaker Replacement: adım 2, 1 resimden 1.
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
  3. Nokia 3120 Speaker Replacement, Face Plate: adım 3, 3 resimden 1. Nokia 3120 Speaker Replacement, Face Plate: adım 3, 3 resimden 2. Nokia 3120 Speaker Replacement, Face Plate: adım 3, 3 resimden 3.
    • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
  4. Nokia 3120 Speaker Replacement, Speaker: adım 4, 2 resimden 1. Nokia 3120 Speaker Replacement, Speaker: adım 4, 2 resimden 2.
    • Once the cover plate has been removed, the existing keypad should be easily removed.
  5. Nokia 3120 Speaker Replacement: adım 5, 2 resimden 1. Nokia 3120 Speaker Replacement: adım 5, 2 resimden 2.
    • Once the keypad has been removed, unscrew the 6 exposed screws on the front of the phone.
  6. Nokia 3120 Speaker Replacement: adım 6, 1 resimden 1.
    • Once all the screws have been removed, the front part of the phone should be removable from the rest of the phone.
  7. Nokia 3120 Speaker Replacement: adım 7, 1 resimden 1.
    • To remove the speaker from the phone, take a pencil or sharp object and poke the speaker free from the removed front part of the phone.
    • To install a new speaker, simply place a new speaker in the same location and put the phone back together.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Pierre Tong
92 İtibar
4 adet Kılavuz yazıldı
Ekip
Clemson, Team 13-2, Benson Spring 2013 Clemson, Team 13-2, Benson Spring 2013 üyesi
CLEM-BENSON-S13S13G2
3 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 1,383
