Ana içeriğe geç
Nokia 3300B Keyboard Replacement.
  1. Nokia 3300B Keyboard Replacement., Battery: adım 1, 2 resimden 1. Nokia 3300B Keyboard Replacement., Battery: adım 1, 2 resimden 2.
    • Flip the Nokia 3300B over with the back-side facing towards you.
    • Gently press the button on the back of the battery cover to release the cover and slide up.
    FixBot'a Sor
    Yorum Ekle
  2. Nokia 3300B Keyboard Replacement.: adım 2, 2 resimden 1. Nokia 3300B Keyboard Replacement.: adım 2, 2 resimden 2.
    • Lift the battery out of the back of the phone.
    • It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
    FixBot'a Sor
    Yorum Ekle
  3. Nokia 3300B Keyboard Replacement., Keyboard: adım 3, 2 resimden 1. Nokia 3300B Keyboard Replacement., Keyboard: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Gently push the blue tabs on the top of the phone out of their slots.
    • With the phone facing up, pop the blue faceplate off by using your fingernail (or some tweezers) and working your way around the phone.
    • Note: If the blue cover does not detach easily use your finger nails to try and split it open, as seen in the picture.
    FixBot'a Sor
    Yorum Ekle
  4. Nokia 3300B Keyboard Replacement.: adım 4, 1 resimden 1.
    • With the screen still facing you, lift and remove the blue faceplate.
    FixBot'a Sor
    Yorum Ekle
  5. Nokia 3300B Keyboard Replacement.: adım 5, 1 resimden 1.
    • Grab the sides of the keypad and lift each side up vertically, until the keypad is completely removed.
    • If you encounter resistance while removing the keypad, be sure to lift up evenly on both sides to ensure that the pins do not snap.
    • When replacing the keypad, make sure that the plastic pegs all enter their proper holes.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Chris Colwell
116 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-65, Johann Spring 2010 Cal Poly, Team 18-65, Johann Spring 2010 üyesi
CPSU-JOHANN-S10S18G65
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 36
Her zaman: 3,414
